Thanks to Tony@EPL (and Al @ CPT) - another K24/18g car lives!
So, after reading a bunch about turbo upgrades, I decided to take the leap into the K24/18g turbos.
I already had K24s since I have an X50 car so the cost was a bit more reasonable than starting from scratch.
I decided to use EPL as I've had some experience with Tony through the audi community. Kept the stock injectors, put in a 5bar FP as rec by EPL and got their new flash. This is an off the shelf kit. No boost controller.
I had the stuff installed at CPT (Chicago Performance and Tuning) and they did a PERFECT job. Their attention to detail is awesome and Al's service (the owner) was great as usual.
Not sure if anyone recalls my post, but, I did a before dyno where it was revealed my car was chipped. This was confirmed when Tony got the ECU and found a soldered on chip. We are not sure which manufacturer installed it, but it was there.
Anyway, here is a before and after dyno (note: the "before" plot is from when I thought I was stock). This is on a Dyno Dynamics dyno. A stock K16 car put down ~330whp and the same car after a flash and exhaust put down ~380whp. My "before" HP was 418whp (not printed on the dyno plot):
Here is the before and after of boost and a/f:
I picked up the car last PM (live in Chicago) and it was raining and 32F outside (not a good mixture for summer rubber).
I did have a nice opening on the highway and it pulls HARD - until it breaks loose! More to come once it gets dry outside!
I did get a nice 40mile drive to test the drivability - it is PERFECT. Feels completely stock until you hit the gas.
I need to find an exhaust as I'm running test pipes currently and it's a "bit" loud.
Anyway, my experience with EPL was awesome. Tony is a class act, readily available for questions.
I can't wait for the roads to dry out. I wasn't planning on driving it much in the winter as i still have my S4 with winter rubber for that. But, this might have just put me over the edge - I think I need some winter rubber
Thanks again Tony and Al - nice work.
You went a whole day without modding your new car....you need to work on that .
What are you waiting for!!! I hear a pair of 18G's calling you!!!
Jason,
I am still debating between k16/16g and k24/18g. Seems like for about $2500 less..you can get the same power...not sure if this is proven. I personally would be very happy with 500 -550 whp on pump gas.
Any insight?
Any insight?
We have a full upgrade path from 550 crank hps to 700+ crank hps utilizing the k24/18's.
Shoot me a pm if you would like to discuss further.
Tell Tony what you want and he'll guide you towards the light...
so far i got 1 pm from you. Is that the one you are referring to?
