Evolution of my 996 Turbo
#183
You guys successfully get above 9100 rpm's with the dynamics of the boxer motor for any period of time ......... then you will make history.
#184
Joe,
I'm a little late coming to this thread. It looks like your intake plenum is a modified World Cup plenum. Is it? EVO did one for me and that is why I asked. I thought they gave up on it ........ I liked it.
#185
I will take that as a bit of advice from someone who I know has been down that road
#186
Not to say it can't be done. I tried and gave up. The boxer motor is extremely smooth to 7000 rpm's. Above that and the design slowly becomes less smooth to about 9100 rpm's. Above that and the opposing forces start becoming exponential and the motor literally starts to tear itself apart.
#187
I was waiting for you to pick that out,because I know you have one.It is highly modded on the inside......I am not using nitrous like you so i can not reap the benefits of that "giant mixing chamber" ......so Evoms changed it to their specs which they felt were better suited to my motor and required some tedious fab work.John told me the reason for the change was after his calculations with the new heads and other bits we still needed to flow about 250cfm more are through the intake.Here's a question for ya Chad....Do you have any idea as to what mph a stock bodied 996 will take flight?I think we are geting closeand I know you are definetly gonna be there when your done....stock bodied or not.
#188
Joe,
It will be great if EVOMS can come in and chime in to tell us something regarding the specs of the head work. It is a small community here and we all learn new things every day. Todd Z is a very knowledgable guy and respected among his peers. I always appreciate his wisdom when I've talked to him and he makes himself available at all times unlike other vendors I know. Thanks for posting the pics of the heads and new Y-pipe design. Hope you guys break through more innovations and research. Cheers, Art.
#189
what specs are you looking for ?They are a cnc'd turbo casting.The valve sizing is the same as the GT3 heads i had previously on the car.You can compare the difference in size to the stock valves compared to the new valves in the pic below.They outflow the GT3 heads i had previously on the car by about 15%.Do you want specific flow numbers?I hadn't seen yours posted so I would need to know at what spec they were flowed at in order to compare.Without that it would be like comparing two cars on different dynos on different days and you know how that goes.
#191
Joe, this is such an amazing car and I love how it's constantly evolving, pushing the envelope of what can be done with these cars as well as keeping you from getting bored lol Not to mention, I'm sure the diet your wallet has been put on, ensures that it'll fit into the pockets of even your tightest fitting jeans. Quick question, where is the Air Filter(s) being relocated to? Are they fabricating a new custom air-box or are they doing something similar to the Proto filters?
#192
Thanks for the kind words,ScottThe filters are right on the turbos as of right now.Evoms has not decided on a final location but are experimenting with a few scenarios
#193
I would be interested in knowing how your flows compare to mine. I have had mine posted for some time in my thread, but here they are for those who have any interest.
You say GT3 valve ...... Street, Cup or RSR. Taking a gander from the pics they look to be Cup size.
Flowed at 25” water. Inlet bell and Exhaust outlet used. I'm showing the flow for intake and exhaust at the corresponding valve lift.
lift 0.050”, intake 52.3 cfm, exhaust 40.9 cfm
lift 0.100", intake 97.5 cfm, exhaust 92.2 cfm
lift 0.150", intake 144.0 cfm, exhaust 144.7 cfm
lift 0.200", intake 194.0 cfm, exhaust 179.2 cfm
lift 0.250", intake 237.6 cfm, exhaust 204.8 cfm
lift 0.300", intake 272.8 cfm, exhaust 225.3 cfm
lift 0.350", intake 297.3 cfm, exhaust 238.7 cfm
lift 0.400", intake 310.7 cfm, exhaust 250.9 cfm
lift 0.450", intake 320.9 cfm, exhaust 259.2 cfm
lift 0.500", intake 324.5 cfm, exhaust 266.2 cfm
lift 0.550", intake 327.2 cfm, exhaust 272.0 cfm
#194
I have been in a 996tt in Germany at 236 mph. I have been told these cars can develop lift issues anywhere above 225 depending on the road and wind conditions. I was also told 242 is really looking for trouble in good conditions.
#195
Hey Joe i was looking at this picture but i could sware that Todd from Protomotive came out with this set up years back, i actually have it installed on my car and i am sure there are many others out there that have it as well, minus the fancy name plate, and i have not intalled the BOV on the tubes but its generally the same set up unless you say diffrent.. Correct?
