Pics of my turbo on Fuji speedway
Fuji short course this time - very technical course and understeering is killing me will put on some H&R sway bars and go back and see if it helps.
I'm running stock size (225/40 295/30), Pzero Corsa, very sticky, quite like them.
great pics and glad you are at the track but H+R bars wont really dial out the understeer would live the front stock and GT3 the rear.
And of course I need to go DE a lot more In Japan we have a DE event on a frozen lake coming up in a few weeks, cant wait
nice tire setup, any specs on the front/rear psi you're running there? i'm sure the temp. & humidity is very different than the states-side or Taiwan (where i'm currently @ right now).
btw, i'll be heading to Tokyo on the 7th of Jan. for TAS @ Hakuhmari from 9th~11th, then back to the central tokyo area from the 11th till as late as 15th or 16th; any chance of you stopping by TAS during that weekend?
If you can I'd definitely get a good set of adjustable F&R sways. Having adjustable sways will help mitigate body roll by allowing you to adjust the total amount of roll stiffness that comes from the front and rear axles. By increasing roll stiffness at the rear you will cause the outer rear wheel to run at a higher slip angle, and by doing the opposite at the front the outer front wheel will run at a lower slip angle, which will give you more oversteer or less understeer.
Also, several tuners dont reccommend using the GT3 rear sway on the Turbos because the geometery was designed around a narrow body car so it's a bit off.
Ron - for the JIC, make the rear softer for a tight turny technical course. This will allow the rear end to squat more and gain you more traction instead of hopping helping induce understeer. Like Tom said also, just doing the rear sway bar will help with that as well. On the AWD car it is easier to create more oversteer and let the AWD system pull you through the turns.
