divertervalves
Old 12-29-2008 | 04:59 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
divertervalves
anyone taken out their dvs? looks like u need small hands...any step by step info would be great thanks in advance steve p.o. any brand better than the rest ?
Old 12-29-2008 | 05:37 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
I just installed the EVOMS ones...the old ones where leaking ...and the car is running much stronger... Sure my 60-130 will go down.
Steve, you have to remove the Air box, loose the driver side IC hose just from the Y-pipe, then near to the Oil filter loose the +/- connections just over the first DV. Then loose the clam that connects the Air intake Pipe to the Y hose pipe that connects the base of the two DV, this is really important. Now, loose the clam of the F hose that connects the Y-Pipe and the first DV and then remove the first DV by just removing the clam in the base.
After that, you have more space to rotate opposite clock-wise the Y hose pipe that connects the base of the two DV, to locate in a more comfortable position to "un-clump" the second DV.
I hope its helps
Old 12-29-2008 | 05:38 PM
MariusL's Avatar
MariusL is a jewel in the roughMariusL is a jewel in the roughMariusL is a jewel in the roughMariusL is a jewel in the rough
http://www.awe-tuning.com/media/pdf/AWE_DV1_996TT.pdf
Its a ****ty job, next time I will rather pay my dealer to get it done!
Old 12-29-2008 | 06:06 PM
deardara's Avatar
deardara is infamous around these parts
get this hose clamp pliers first
vividracing's Avatar
Old 12-29-2008 | 06:13 PM
thanks guys am really not to stoked about the lack of room on this job , but am going to get my hand cut up wed thanks again have a safe new years
Old 12-29-2008 | 06:15 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
I went with the kit from Vivid. Good quality and have functioned well for several months. Can't provide much step by step bc I did it when a good bit of the back end was apart already.
Old 12-29-2008 | 06:42 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
My local guys did it by dropping the engine just a little...made it trivial (I was told)....under an hour labor...not sure how hard, but fyi.
JB
Old 12-29-2008 | 07:18 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
It's not a hard job, it's just VERY tight in there. Take your time and you will do fine.
Here is a DIY done by Stephen Kaspar at IA: http://www.turbo911.com/showthread.php?t=287 It is very helpful!!
Old 12-29-2008 | 07:30 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
After reading one of the discussions and suggestions....I went out and bought those cable pliers and ended up using a pair of the bent needle nosed pliers....the cable pliers just wouldn't quite stay on the spring clamp nubs....$35 at Sears for something that didn't work and I'll never use again. I also didnt' replace those ford clamps with the stainless screw type and ended up with a leak at one of the diverter valves where it seats at the bottom...not in the F hose....so make sure those DV's are seated properly or you'll have boost problems. If you do notice boost issues....go right back and re examine the connections.
Old 12-29-2008 | 09:26 PM
Scottslaw's Avatar
Scottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond repute
Dang, bummed to hear those cable pliers didn't work for you. I've got a new f-hose coming (small leak), and I was planning to purchase a pair hoping that they would make the job easier. I've changed dv's on a friend's car, and the above posters are correct...bloody hands for sure!
Old 12-29-2008 | 10:00 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
If you lived close to us, Turbo Mike would have done this job in less than an hour for you. He has huge hands but does amazing work, just like a surgeon. Hope you fix it soon.
Old 12-29-2008 | 10:06 PM
Go down to Harbor Freight if you have one near you....or anywhere that sells the cheap chinese pliers....get a pair of the fairly good sized needle nosed pliers that have a bend in the jaws....that bend allows you to get behind the back side of the diverter valve and compress the nubs....then when you get done, you can go to the emergency room and get a pint of blood to replace all you've lost during the procedure.
Old 12-29-2008 | 10:10 PM
thanks for the help gonna pressure test and be sure i have a failure before i replace them. then i'll give it a shot.. have lots of bandaids thanks again ain't this a great place
Old 12-29-2008 | 10:16 PM
art4iza's Avatar
You will fix it, no worries bro. It is not as hard as they say. The damn small space is not fun to work in though.
Quick Reply: divertervalves
