k24/18g setup with or without EBC??
Old 01-20-2009 | 12:56 AM
drjoe's Avatar
drjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the rough
Originally Posted by anthracite
Sean,
Dont worry i told you already that you are on top of the list to get this when we got it done
hey, I've been holding off patiently for Two years for this standalone...I want a dyno and street tune too please,
  #107
Old 01-20-2009 | 03:46 AM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Originally Posted by art4iza
What is the update Flash68 on the thread? Where are you with the modds?
Havent moved on it yet. Still trying to finish the Camaro and get that done and want to get to work on modding the 996TT right after that. Hopefully by March!
  #108
Old 01-20-2009 | 08:22 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Originally Posted by justinn
I just thought I would update everyone on the status of the "standalone" in the 996TT.
After grabbing all of the data I felt I needed over the last few weeks, and finally getting some time to do the remainder of the wiring, it's up and running.
There are no major CEL's... I say major because I did get a CEL for the O2 sensor heater circuit(probably my fault in the first place), but other than that everything seems cool. I will change the spark plugs tomorrow and quite possibly in the afternoon put her back on the dyno and compare stock to standalone numbers.
I am currently running off of the factory MAF and injectors, but will be switching to speed density and larger injectors shortly, thereby getting rid of that nasty convoluted intake pipe.
I just wanted to let everyone know that it works fine.
Justin
Congrats! I need to find some time to get ours done as well, if this damn race for the 6spd record would end already it would be done LOL.
Just curious , Did you use the Standalone to control drive by wire or using the factory ECU for this input ?
Boost/Gear should be fun, I'm thinking at a track like Sebring I can have the car turned way down gears 1-4, and then have full boost in 5th for the backstraight, should make for some fun passing!
-Wes
need4speedmotors
996 Turbo Vendor Classifieds
01-12-2016 06:41 PM
COBB Tuning
01-05-2016 08:06 AM
shifter_
09-30-2015 05:00 PM
PBass
09-29-2015 11:28 AM
need4speedmotors
997 Turbo Vendor Classifieds
09-28-2015 05:47 PM
