K24 & K24/18: Are they really different ?
Old 01-08-2009 | 08:45 AM
ThePunisher's Avatar
ThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud of
I can't stop reading about the difference between a K24 and a K24/18 ... some says that the difference can be calculated in 60 HP, some others talk about 100 HP !
Why ? Is there any reason which can lead me to believe that this is true ?
If a K24/18 is able to produce 40 lbs/min ... means that can produce 18.14 kg/min (excuse me but i prefer to work with kg. but nothing changes at the end)
So, 18.14 kg/min is 0.3023 kg/sec. and can be converted in a max power of 329,65 HP each turbocharger ... without dispersions meaning that this power will not be possible in the real world (but just something less).
Now some say that a K24 produces 30 lbs/min ... 13,61 kg/min ... 0.2268 kg/sec. and a max power of 247.32 HP, but the problem is that a K24 produces a lot more then 30 lbs/min !
Borg Warner which produces this turbocharger, and is supposed to know better then any other the K24, says that this turbochargers have a max flow rate of 0.30 kg/sec ... 327.14 HP.
That's the point:
K24/18 max flow rate 0.3023 kg/sec and 329.65 HP
K24 max flow rate 0.3000 kg/sec and 327.14 HP
Where is the difference ?
Old 01-08-2009 | 09:17 AM
dreamtripper's Avatar
dreamtripper is infamous around these parts
As a reference point, how would a K16 turbo rate in your calculations?
Old 01-08-2009 | 09:21 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
are you using fuel and temp as a constant in your calculations?
Old 01-08-2009 | 09:36 AM
jasonfreed's Avatar
jasonfreed is infamous around these parts
Here is a before and after dyno plot of my car with K24s (chipped - unsure which chip since i bought the car used and the owner told meit was stock) vs. K24/18g with an EPL tune:
Obviously, the red lines are the K24/18g turbos. We are not talking about more HP at a particular point. Look at how much HP and torque these things make throughout the power band!
Old 01-08-2009 | 09:38 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
If you race two exact same cars with only difference the k24 Vs k24/18g turbos(and of course the corresponding ECU tuning) from rolling 2nd to 250km/h the difference is about 3 to 4 car lenghts...
On the other hand when K24/18g turbos are used you can raise up the boost and put in good racing fuel as well as bigger injectors...Then you will see great difference...
Old 01-08-2009 | 09:42 AM
A K16 has a max flow rate of 0.26 kg/sec ... 283,52 HP which means 560 HP in a 996 TT clearly not possible because this is the power that K16 can produce but not the power the engine will produce but we all know that a well remapped 996 TT with oem K16 can easily achieve 490-500 HP
Old 01-08-2009 | 09:45 AM
Yes, temp 293 K press 981 mb and fuel not important for me in this calculation
Old 01-08-2009 | 09:49 AM
Yes i can see but here's the point ... are you sure were you getting the max power from the K24 or just the power the tuner wants to give you ?
Numbers are numbers and don't lie ... Borg Warner doesn't make mistakes about the calculations on the turbos is producing !
If K24/18 produces a max air flow of 40 lbs/min this means only one thing ... is equal to a K24 ... other endings are not possible !
Old 01-08-2009 | 09:52 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
interesting...
Old 01-08-2009 | 09:55 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
That's the point:
k24 and 18g compressor map for reference.
Old 01-08-2009 | 09:56 AM
I can run 1.25-1.30 bar at max rpm power with a K24 ... which boost do you think you can get from a K24/18 ?
Numbers doesn't confirm what you say ... if we make work the K24 as it can work and not as some tuner say !
K24/18 40 lbs/min
K24 39.6 lbs/min
Until these numbers are correct they are equal !
Old 01-08-2009 | 10:54 AM
to be honest with you i did not had a great look over the numbers...However during past time i had my car at k16,k16/24,k24 and k24/18g setups...So...max boost sustained with k24 was 1,2 to 1,25 while k24/18g can very easy get to 1,4 bar...These turbos are not equal...They have a very noticeable difference especialy as revs go up...
Old 01-08-2009 | 11:00 AM
vividracing's Avatar
Here is 2 dynos to compare. K24/18G vs K24 Stage 2 -
Old 01-08-2009 | 11:16 AM
MBailey's Avatar
Is this with stock fueling system or a 5 bar FPR on 24/18g?
Old 01-08-2009 | 11:18 AM
All K24/18G kits should be run with the 5bar FPR only unless you have something different and creative for the motor.
