Not feeling the power out of my 24/18g's. HELP!
Old 01-11-2009, 08:57 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I'm a little frustrated here. I'd like to hear from those of you running 24/18g's, especially from Tiptronic owners. What are your 60-130 times? I feel that I should be much quicker than low 8's. I'm using 93 octane with a Softronic tune. I'm hitting 1.3 bar. I've got 60lb injectors, stock maf, stock 3.8 fpr, headers, miltek exhaust. I've data logged engine load numbers, lambda bank 1, blah blah. The AFR looks fine.
Your thoughs. Thanks guys.
Old 01-11-2009, 09:05 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Are you using an EBC?
Old 01-11-2009, 09:08 PM
No, I'm not.
Old 01-11-2009, 09:26 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
What does a 6speed k24/18g car do 60-130 in? I believe in the 7s...
Old 01-11-2009, 09:33 PM
At least mid 7's.
Old 01-11-2009, 09:52 PM
Member
An EBC seems to control the boost better than the stock boost control sytem, but this depends on your tuner. A related and more fundamental question...do you have stock or upgraded wastegates? Stock WGs will hurt your power at these power levels.
You are asking the right question though...I don't know what other 24/18G tiptronics are either. But...low 8s are nothing to sneeze at. IIRC stock 6speed 996TT is 12s.
Old 01-11-2009, 10:28 PM
Dr_jitsu's Avatar
Todd,
There is at least .6 seconds difference, or 3 car lengths difference between a 6 speed and a tip. I know this from running against both in real world conditions. I was shocked at the difference. Although I think that your car should be faster than it is a tip needs about 80-90 more ponies to run even w/ a manual.
Old 01-11-2009, 10:31 PM
flash68's Avatar
Don't forget he is RWD....
Old 01-11-2009, 10:41 PM
Dr_jitsu's Avatar
As per our discussion , Todd if you get a proper hands on dyno tune and an EBC with the abilty to run some race gas your car should be down to close to the mid sevens. That is certainly a fast car by most standards.
Old 01-11-2009, 10:50 PM
drjoe's Avatar
drjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the rough
dyno the car to see if it makes the power first...but yea 8 is not slow
Old 01-12-2009, 03:49 AM
ttboost's Avatar
Anyone know the driveline loss is on a Tip? I know I lose 19% on my stick. If the "average" 6 speed 18G cars makes 500-530AWHP, what SHOULD a RWD Tip make?
Old 01-12-2009, 04:06 AM
flash68's Avatar
19%? Is that a typo?
Old 01-12-2009, 04:54 AM
ttboost's Avatar
Nope. My car dynoed 336awhp stock (415 fwhp-stock) 415x.81=336. Rear wheel drive is closer to 12%-15%. Typically an RWD car should make 25-40 more hp.
Old 01-12-2009, 08:13 AM
MBailey's Avatar
I think the RWD conversion should nearly cancel out the effects of the tip. I believe he is significantly down on power for the mods listed...
Old 01-12-2009, 08:47 AM
Turbo Fanatic's Avatar
Do you have a fuel pump? What do your AFRs look like? 1.3 BAR, I'm assuming you are using race gas?
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
Quick Reply: Not feeling the power out of my 24/18g's. HELP!
