Which scanner to get? Durametric or Auto Engineuity?
Old 01-19-2009 | 03:21 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Well, I dropped off my car today at the stealership to have an allignment done $350....not too bad....but than I wanted to have them clear the airbag light that came on when I took the door panels apart and the guy tells me it will be $199 just to hook it up to the scanner without even clearing the light...so I figured for not much more I can get one of the readily available scanners....so Which on is better way to go and why???
PS> Since this is the first time I acutally got to drive this car on a long stretch of road and I hit 1.1bar I assume the car is flashed (I got it a while ago but needed to do some suspension and body work so I didn't drive it) The question is ....how do I find out which flash/chip I have???
Other than that the car seems stock.
Old 01-19-2009 | 03:36 PM
jpflip's Avatar
Durametric
I got a Durametric and really satisfied with it. Especially like the "drive links" to do proper troubleshooting. But cannot compare because I never saw the other model...
Old 01-19-2009 | 03:41 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
I've used Durametric to clear my airbag light when I install my yellow seat belts. Very easy to use, much better options than going to stealer!
Old 01-19-2009 | 04:28 PM
MBailey's Avatar
Use Durametric. Very satisfied.
I cant answer your second question.
Old 01-19-2009 | 08:02 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I use Durametric. Works great. But I don't know how I check which flash you have. Good luck.
Old 01-19-2009 | 08:06 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
I have the Actron CP9145 and it is very easy to use - no problems for the few years I've had it.
Old 01-19-2009 | 08:45 PM
smdubovsky's Avatar
smdubovsky is infamous around these parts
I used my durametric on the wifes boxster to track down a dislodged cat/bad O2 sensor problem. Good software, no complaints. Far more advanced than the actron code reader I've used (sorry don't remember the model)
Old 01-19-2009 | 08:56 PM
RiA's Avatar
RiA
Durametric is more advanced than the Actron - I agree.
Old 01-19-2009 | 09:48 PM
adam699's Avatar
How about the Auto Engineuity?
Old 01-19-2009 | 10:01 PM
I have been told that Auto Enginuity works really well... it even givesd you afr readings.... something most other programs do not...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 01-19-2009 | 10:44 PM
WSY996TT's Avatar
WSY996TT is infamous around these parts
can durametric erase spoiler malfunction light?
Old 01-19-2009 | 11:17 PM
drlaw99's Avatar
drlaw99 is just really nicedrlaw99 is just really nicedrlaw99 is just really nicedrlaw99 is just really nice
Anyone try a Speedtech RS-9000 or a Scan Gauge II?
Old 01-20-2009 | 10:32 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
I don't recall the Durametric being capable of A/F ratios but I believe it will give a real-time log of lambda. Problem is that it won't sample fequently enough at high RPM to give any meaningful data.
Old 01-20-2009 | 04:01 PM
Dr_jitsu's Avatar
When I datalogged using my Durametric it gave A/F ratios...of course Alex was using his laptop and I was just driving.
Old 01-20-2009 | 05:10 PM
adam699's Avatar
I'm more confused now than I was when I started this thread
Any more info? Who are the vendors that sell these and what are the prices?
