Who has used E85 in the Turbo?
wish I would have finished my new setup a day before I would have sent my 044 kit over to you. which fitting held you back?
What are you putting in now ? I assume larger injectors but what about pumps ?
On the same day I saw (2) Different cars on a Dyno, dyno higher on E85.
Being in the Cornbelt, we have E85 on almost every corner, and have Ethanol Plants
scattered all over Minnesota. I discussed this with Tym Switzer, it is very doable but
requires lots of fuel. One of my buddies tuned his Supercharged Viper to run an E85
with larger injectors and monster fuel pump/lines etc. E85 is dirt cheap here in the corn belt so lots of young hot rodders run it in their cars, in everything from Firebirds with big block Chevy's (N/A) to turbo cars (Big Single Turbo Camaro with 1100 RWHP to SuperCharged Vipers.
E85 is a $1.35 to $1.60 today in Minnesota
http://www.e85prices.com/minnesota.html
marty
marty
For having advantage from E85 you need big fuel lines/injectors (capable of E85 without melting) and than a ECU remap with lots of ignition advance (+5/6°).
You get high power, low EGT's but .... Extremely high cylinder pressure!!! Danger for pistons/rods
04-28-2022 12:38 AM
turbotuner20v
09-11-2015 12:02 PM
johnny.dangerous
08-21-2015 10:48 AM
