Realistic HP expectations
depends on boost and fuel... pump gas it will run 600 crank with a 5 bar at 1.2 bars...
2001 996TT 3.6L and stock ECU
If your planning on going with protomotive, they can supply the injectors. I believe they use siemens injectors, which cost about 300-400 for a set of 6.
This sounds about right ^^^^ Markski knows his stuff!
I am estimated 650-670 crank HP at 1.4 bar and I have
more fuel, turbo and I/C than you. 0-300 kph in less than 27 seconds
(same as RUF RT12 and similar to ENZO for comparison).
Good luck, great car!
MK
The siemens 60lbs. injectors are more like $500+ and then you need adaptors to extend the fuel rail...
if u run 60lbs injectors u need a 3.8 bar stock fpr. Also the tuning has to me adjusted.
rc injectors do not have a good rep on our cars
