Big wing conversion question (GT2 decklid upgraders, this is for you guys!)
I bought samboTT's big (think Tom Kerr's Getty Design size) wing.
Let's say I plan to put it on my car permanently. I need as it is coming to me to move my fan, harness, and the plastic stuff that says mobil one/emission on stickers over. The lid is OEM turbo, so this is going to be trivial. Lids bolt on fast if you look at the MAShaw site, he says it is 5 minutes).
So I do that and plug it all in, I'll be missing the hydraulics (and the weight ), and will get an error message.
Is there a simple solution to making the error solution go away?
Searches on this site yielded some confusing data, hence my post:
1. There is a hack to cross wires.. IA post by S.K.
2. There is a rumor of a 30 dollar harness from Misha. Misha, is this true?
3. There is a "go to the dealer and the PWIS can just turn that off permanently" implication in many posts, but I am not clear about this...is it forever, etc.
Thanks everyone in advance. Given the huge number of GT2 decklid conversion (and other decklids) here, I figure someone must have a simple, affordable solution.
Jeff
Jeff
from what I've seen, the 3 ways you've mentioned are all proven methods.
I was told Mashaw had a 30 dollar harness...he didn't though. He had a 200 dollar harness. which you could also get at the dealer.
Misha didn't have one. I checked.
I'm going to try the dealership method. Using their tool to set that option to off should be the least painful. Once I get to doing it, I'll let you know (unless you end up going before I get a chance)
ya. it's like 200 dollars or so.
Small Shrimp: So, you have a stock (hydro) harness and it was turned off, or you have a gt2 harness form dealer or MA Shaw and you had the light turned off...
Thanks!!! Thank you everyone! I just want the cheapest/easiest option....I have the original stuff in hand and would love to just use it.
Jeff
Jeff
This is all I know in the jpeg attached. I am assuming it will work if you take a stock harness out of a stock decklid and put it into a gt2 or other big decklid with fixed wing, as your post suggested....found this via search. It was answering a person's question about keeping the stock wing up for good (or down)...just seemed to make sense if there was not wing motor at all. My post here is meant/aimed at getting confirmation from you guys out there who have done this.
TIA
Jeff
TIA
Jeff
Jeff,
When you do this, would you please take some pictures and document the procedure? I'm getting ready to do this, too.
Regards,
John
Regards,
John
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Sure. The wing is in the mail. I have to paint it midnight blue...so it will be a bit of time. But, yes.
Stephen is quite clear in his writing, so I hope it is easy. I figure if the sensor is crossed and the motor is d/c'd, it "should" work...
I emailed him (PorschePHD) and I suspect he'll get back to me in a day or two.
Jeff
I am hoping it looks a little like this, but in midnight blue.
Jeff
Yup this can be done. I am not 100% sure on the years that it applies to, but the car is basically told that it is equipped with a factory aerokit, ie...no hydraulic wing. This may or may not be aplicable to early 996TTs, because I don't think the aerokit was an option, however it still may have been programmed to not have it, even if it was not an option. No hacking of wiring, or ordering harnesses, and is pretty simple to reverse if one decides to go back to hydraulics.
We are all sure durametric cannot do this. I don't have one yet...and that to me would be justification...I have a generic code reader right now....pep boys...does what I need when used with Google.
Thank you!
Jeff
I'm utterly useless in this thread, other than to say my car came with a GT2 rear wing/decklid(?) and I have zero errors. I still have the button on the dash for the wing, but it is turned off or unplugged...
Good info...
Mike
Good info...
Mike
