How many hours labor to replace plugs,diverter valves,..do I need
Old 02-26-2009 | 10:15 AM
Scottslaw's Avatar
Scottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond repute
Wow...I feel bad about my wrenching skills after reading this thread. I easily spent 5 hours my first time doing plugs, but I took my time. I bet a good mechanic could do it much quicker.
Old 02-26-2009 | 10:47 AM
kennyjr748's Avatar
kennyjr748 is infamous around these parts
I've been quoted 5 hrs (just to do plugs) from two reputable shops in the bay area. Must be the going time for independent shops around these parts...
Old 02-26-2009 | 12:12 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Yip... taking your time 4 hours is about right... once you have done it a few times you should get it down to half that.
Old 02-26-2009 | 12:32 PM
Originally Posted by STEVE KOJASEVIC
lol 4-5 hours ?
remove the rear bumper .. i think its 4 or 6 bolts
I'm sure it's about 12
remove both intercoolers
that about 5 minutes for each side
15 minutes each for newbie... half that if done a few times
removing and replacing each spark plug with proper torque is about 2 minutes per plug
This is where you should take your time... 5 minutes a plug
its about 45-50 minutes for the plug job
45-50 minutes!!!!! Don't know what you mean
15 minutes for the diverter valves
Are you for serious? Could be anywhere up to a couple of hours for a newbie, well under half that time if done a few times
and another 15 minutes for the coil packs
Again think you will find this job should not be rushed and they need properly clipped in... more than 15min
clean off the intercoolers
put everything back on
remove car from lift/ jack
and youre all done
If you do it in your times, I would be expecting missfires, boost leaks and a bumper falling off half way down the road
Old 02-26-2009 | 05:17 PM
Soul's Avatar
Soul is infamous around these parts
^ lol
Old 02-26-2009 | 05:21 PM
Scottslaw's Avatar
I just remembered that I also removed the taillights and the exhaust heat shield. I seem to recall that I probably didn't have to remove the heat shield, but for some reason removing the taillights was required/helpful.
Old 03-07-2009 | 07:37 PM
raineycd's Avatar
lol 4-5 hours ?
and youre all done
Did my plugs today with the help of a couple of guys and a lift. Took 3 hours for just plugs. It is not a super difficult job, just lots to take off and put back on.
I think your estimate of times is very optimistic!
Bumper has 3 - 4 bolts on top, four on bottom and two top sides. You also have to take off the bumperettes and tail lights and disconnect the plate light wire harness. Simple, but not 4 - 6 bolts... Then you have to take off the rear inner wheel well liners and I would pull the rear wheels if I did it again. Gets to tight with the tires on.
5 minutes to take the intercoolers out each side! I would love to see it done in 5 minutes! Have to take out 5 bolts, two heat shield nuts disconnect two hoses and wiggle it out. At least 10 - 15 minutes per side if you know what you are doing. If you have air ratchets and everything lined up with an assistant, you might get it at 5 minutes.
Changing the plugs in 2 minutes. Yeah, if you are staring at them. Have to take out the rear heat shield, bend the side ones up, take off the heat sheilds on the heads, then take out each coil pack all in a confined space. Once you get that done, then 2 minutes per plug to take them out, inspect them, then install and torque. Again, not a hard job, just tight and many bolts.
Anyway, 45-50 minutes for a plug job with one person is totally unrealistic! I think I could probably do it in 2.5 hours now with help. We had to locate a hidden intercooler bolt on the first side that killed about 10 minutes and I would take the tires off that would save a little time.
Anyway, just my 2 cents. Did you change yours yet? I think you mentioned in a thread you were going to do it soon?
Thanks!
Chad
Old 03-07-2009 | 07:40 PM
raineycd's Avatar
Originally Posted by Seal Grey Matte
And don't forget to plug the wiring harness for the license plate light back in when you put the bumper back on. Ask me how I know.
Oh crap! I cant remember doing that! Dang it! I was in a hurry. I need to go and turn the lights on and see. I sure hope we did!
-- edit -- Crap! just checked it, no lights... Looks like I get the pleasure of taking the bumper off again. At least it is easy...
Old 03-07-2009 | 07:57 PM
wowgogs's Avatar
wowgogs is infamous around these parts
lol too funny...
Old 03-07-2009 | 08:44 PM
wowgogs's Avatar
I did my divertor valves without taking off bumper, dropping engine .. nothing.
and man it SUCKED! took like over 2 hours and I scratched my bumper.
its soo tight in there.
Old 03-07-2009 | 09:39 PM
Cascade's Avatar
Cascade is infamous around these partsCascade is infamous around these parts
Thanks guys, I had the same question
Old 03-07-2009 | 10:07 PM
heavychevy's Avatar
Wait.............................................. ..................
did I just see............................................... ..........................................
Diverter valves in 15 minutes???????????????????????????????
Old 03-07-2009 | 10:15 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
I did my diverter vales in about 2 hours, with the help of a friend.
Sometimes you need extra power and force to wrestle down some of the cables/hoses in the tight engine compartment.
Plugs is a different animal. What were the Porsche engineers thinking when they decided on the plug location ?
Today I've been working on a full turbo/exhaust swap and deciced to change the plugs while I had so many of my critical components stripped down. Let me tell you...it doesn't go that quick. After 7 hours of work I've taken off rear spoiler, bumper, intercoolers, exhaust, turbos and changed the plugs. Tomorrow the Hybrids and the Europipe go on.
While I performed some extra steps, changing the plugs is NOT a 3 hour job !
04-28-2022 12:38 AM
OldBoldPilot
08-24-2015 04:00 PM
ECS Tuning - VW
08-19-2015 08:58 AM
Quick Reply: How many hours labor to replace plugs,diverter valves,..do I need
