"Navigation" Display on Inst. Cluster
Hello,
After owning my 2002 996 Turbo for 6 months, I finally got the PCM1 nav working after getting the proper cd's with help from this forum. My question is that the electronic display on the instrument cluster has an option that can be selected that shows arrows. When I select this, the word "navigation" shows up on the inst cluster display but thats all it does and does not show the directions. The PCM1 continues to show the directions.
Should the directions also be shown on the inst cluster display when I select the nav function on the menu? If so, how do I get it working, and If not, then what is the purpose of having this option on the inst cluster display menu?
Thanks for your help,
Z4MET.
Z4MET.
It will just say navigation unless you have programed a destination and activated the route. Then you will get arrows and other info on the center of instrument cluster. If not I would say something remains amiss.
pwdrhound
11
11-25-2015 01:18 AM
