Rear spoiler cylinders
Strathroy kindly sent me his hydraulic spoiler system for exploratory diagnosis.
The interesting thing I have discovered so far is that the pump unit seems less a pump than a pair of cylinders which when stroked by the motor ram assembly, force oil proportionally down the cylinder lines so that the spoiler cylinders then must rise together in unison, as long as there is equal fluid volume in the pusher cylinders. Simple and effective. Probably the only issue is to replace the spoiler cylinder seals as they age, to keep the fluid levels equal. Does anyone have any tech info on the sensors, wiring or anything else related?
Bob
Bob
JPflip;
It looks like the pump is not the problem but rather the slave cylinders which lift the spoiler.
On Strathroy's system I'm seeing slight leakage around one slave rod seal. Over time this would cause that cylinder to rise behind the other side due to air compression. I'm going to replace the seals on Strathroy's system and let them sit under a test rig load to 'prove' their performance.
It is also relatively easy to replace the motor side cylinder seals should that be the problem for anyone, but I have been told by Strathroy and agree this is less likely to cause problems. So far this has been kinda fun !
Bob
Bob
The good news is that the hydraulic pressures are extremely low probably 10 - 100 PSI, so the seals are very lightly stressed.
My submarine systems are rated at 10,000 PSI, yet leaks are not an issue.
Mackchacha
07-09-2019 11:03 AM
3WDistributing
31
10-27-2017 01:26 PM
