New Project called B9R Under Construction...at BBi
#274
Port and polish using a flow bench to match the flow on each port.
#280
For those of you who are going through the costs of porting and polishing, adding larger valves etc., don't fail to give some attention to the two cylinders that tend to heat up more than the others due to water passage restriction. A little work here will enable sufficient coolant to prevent heat build up and the resultant pre ignition problems.
#281
[QUOTE Drilled for 12mm head studs.
[/QUOTE]
I didn't pick this picture out for the head studs. I liked the shot because it shows the webs or crank supports. Notice they come stock with square edges. In the following pics it shows the webs rounded or "bow tailed." The purpose is eliminate windage allowing the motor to respond faster.
[/QUOTE]
#285
Chad, after reading half way through your thread and I almost creamed in my pants excuse my French. The whole work on one side and the lifts and head flows on the other. Pistons look amazing as well as the rods, WOW Intense work and a huge research, congrats to you my friend. I think you know more than the whole Porsche motorsports in Germany
[/quote]
[/quote]
