Got to drive a 24/18G car today...
Gunther brought his gorgious yellow Turbo down to do the brakes on it before he ships it over to Germany. Afterwards we took his car for a ride, and then mine. The cars are similar in suspension components, but different in ride height, alignment, and obviously where the power comes in.
I see the attraction some of you guys have for the 24/18G. The "hit" when the power comes on is impressive. My K16/24s don't have that hit... It's just a tad more linear... I can also tell that my car would probably give up on topend where Gunther's would still pull a tad bit further up high... Nice way to compare the setups...
Of course with Gunther's clutch issues, and my clutch issues, we could combine both and make one nice driveline!
Good to see you again man and thanks for the drive!
Mike
Mike
We didn't have that kinda room to really give an indicator. Gunther's is a proto car and I think that these two would be close, but the K24/18G would probably edge the K16/24 out by a small margain on top end say at the end of the 1/4 or in a 60-130 roll... Numbers on the 1/4 mile and 60-130 list probably will confirm this.
Gunther's car is probably making similar numbers as my car (and I'm guessing here) on pump gas. UMW claims my car should be putting down somewhere around 535-550 WHEEL HP on his tune. Gunther's proto car is probably making somewhere around that and maybe 20-30HP more. It's hard to tell because his comes on later and that hit is pretty impressive. I was having serious issue with operating his clutch, so I wasn't going to chance a missed shift.
Gunther's clutch pedal rides high for engagement of the clutch, and I was stalling it alot... My car has an issue with the clutch hydraulics and unless you're good at heel/toe shifting it'll give you fits... So both Gunther and I were struggling with the whole "shifting" of each others cars...Due to the problems with that, any comparo would be impossible. I need a trans rebuild and Gunther needs a clutch replacement, simple as that.
But just stabbing the throttle on each, mine doesn't have a big "HIT"... It's just always there... The K24/18s really give you a "hit" around 4500RPMS, where they start to spool up... I like what I have and have zero interest in upgrading. I could see it would be more of a challenge driving the K24/18G on a road course due to the increased boost coming on just as you're apexing.
That said, I don't think you'd go wrong with either over the stock K16 or K24 setup.
Mike
Mike
Mike,
Any idea what dyno would that number be expected from? Btw i agree with your review, i drove a k24/18g back to back with my K16/16g car. The 18g pulls way harder on the top end >120 mph than my 16g car.
Mike,
My car hasn't been dynoed and when it is, I will not post the numbers due to all the flamefests that seem to happen when anyone posts numbers. Kevin at UMW does exstensive dyno tuning with his kits and has these numbers verified on his website. I can tell you that he normally runs the cars on his dynos with the rear bumper off and with 5-6 fans running to provide proper cooling. Gunther probably got his number estimate from Todd at Protomotive... I don't believe he has dyno'ed his car either.
We were running 93 pump gas...
Mike
Mike
Mike,
Mike,
Mike,
Mike,
vbmw335,
how did the 16/16g and the 24/18g compare 0 to 120?
I did not race the K24/18g car. Its purely a butt dyno and a reference marker as the back to back runs were done on the same road. So my car hit about the same speed as the 18g car at the same marker on the road up until 110. I also felt like the 16 g hits hard until 110 ish...then the k24/18g car takes off much much harder. Its hands down faster!
All this could be because of higher TQ numbers at early rpms of my car 540 vs low 500 ish for the 18g car. But regardless the k24/18g has a 60 WHP advantage over my car after 4500 rpm.
End of the day ...i am very impressed by the 18 g car...but i rarely drive my car faster than 120.
My guess is ...in a 60 - 120 race...the 16 g car might pull like 1 car length and then the 18g car will pull like 3 car lengths after 120. The 60-130 times prove this theory somewhat.
Mike
Mike
I have tracked my car extensively with both stock K16's (chipped), and with Proto K24/18g set-up. The larger turbo set-up works well and I find
it is more linear in feel for road racing on LOW BOOST (I will just run 1.0 bar at the track). Just another opinion/perspective.
Mike
Mike
Nice write up.
Exactly... We were running 93 octane pump gas and it was in the 70s temps wise... We "should" have run them heads up, but honestly the clutch hydraulics issue in my K16/24 car are sketchy and the issue with Gunther's high riding clutch pedeal concern me as well...
It was nice to drive his car. His car gave a sensation of "power" when the turbos came on. Mine is more linear, and that's about all I can say on the subject...
Mike
Mike
