ticketed for exhaust being too loud...
Old 04-09-2009 | 12:08 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
The iPhone has a sound meter app...it is cheap...in case you need to record the sound level. I am not sure the distance used, etc.
Good luck.
JB
  #32
Old 04-09-2009 | 12:49 AM
huy's Avatar
huy
huy is infamous around these parts
In CA, the limit is 95 decible. I believe they position the meter 3 feet behind the car and hold the engine rpms at like 4500. Basically, there was a law implemented to where you could go to the smog referee and get a exhaust sound test. As long as its 95 dB (+/- 5 dB to account for equipment error) then you are OK. Tubi does tend to be on the loud side, so I don't know...
  #33
Old 04-09-2009 | 11:20 AM
mannytt's Avatar
mannytt is infamous around these partsmannytt is infamous around these parts
Going to a smog referee later today, hopefully its under 95 decible. I guess I will just shutup and pay the fine and move on if its not, but what about the checking under the hood, can they even do that?
  #34
Old 04-09-2009 | 12:14 PM
huy's Avatar
huy
they did look under my hood when my car was there, but they didn't do anything about it.
  #35
Old 04-09-2009 | 12:21 PM
germeezy1's Avatar
germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !
Where you at WOT when he pulled you over or just idling around? What a jerk the Tubi isn't even that loud.
  #36
Old 04-09-2009 | 12:24 PM
Autoscope's Avatar
Autoscope has much to be proud ofAutoscope has much to be proud ofAutoscope has much to be proud ofAutoscope has much to be proud ofAutoscope has much to be proud ofAutoscope has much to be proud ofAutoscope has much to be proud ofAutoscope has much to be proud ofAutoscope has much to be proud ofAutoscope has much to be proud of
Originally Posted by VSE Chuck
sorry to hear about your bad luck...I'm sure he was pissed that you moved the engine
  #37
Old 04-09-2009 | 01:55 PM
Prche951's Avatar
4500 rpm? that's retarded? it should be 2500 rpm as that is closer to where most people drive at. That is what it is in Colorado.
Anyway, what you need to do is have someone with a Harley drive next to you and have another friend film it from 50 feet away. Take that to court and ask them to explain how it is illegal to be more quiet than a Harley.
  #38
Old 04-09-2009 | 01:58 PM
huy's Avatar
huy
bikes have a higher dB limit. they are allowed to be loud so that cars notice them.
  #39
Old 04-09-2009 | 02:02 PM
Prche951's Avatar
well then, they should aim the exhaust forward on bikes so the cars in front can hear them
  #40
Old 04-09-2009 | 02:03 PM
ard's Avatar
ard
What did you get cited for? Modified or too loud? Do you have the citation with the VC section reference?
More info, links to other stuff:
http://www.civicforums.com/forums/98...-included.html
  #41
Old 04-09-2009 | 02:05 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
Not true
Motorcycle Limits
27202. For the purposes of Section 27200, the following noise limits shall apply to any motorcycle, other than a motor-driven cycle, manufactured:
(1) After 1969, and before 1973 .................................................. .................................................8 8 dba
(2) After 1972, and before 1975 .................................................. .................................................8 6 dba
(3) After 1974, and before 1986 .................................................. .................................................8 3 dba
(4) After 1985 .................................................. .................................................. ...............................80 dba
  #42
Old 04-09-2009 | 02:12 PM
Prche951's Avatar
Originally Posted by Onetime
Not true
haha, I have heard Harleys that would make you deaf, and they don't get ticketed. I would definitely fight this ticket.
  #43
Old 04-09-2009 | 02:18 PM
mannytt's Avatar
He didn’t say anything about modified he just said it was too loud.
  #44
Old 04-09-2009 | 02:50 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
Red face
Originally Posted by drlaw99
Maybe should have told him that the exhaust was factory stock. How would he ever know the difference?
I've personally never heard of anyone being pulled over for an exhaust unless they were driving like a jerk to begin with. Not saying that's what happened here. Regardless, if you have factory tips, I would without a doubt say its a factory exhaust. That's what I plan to do with my car. I have an L-Tuned tip on my IS300, but everything else is a straight pipe
  #45
Old 04-09-2009 | 02:51 PM
split's Avatar
as for 80dBa, where do they measure from? I'm pretty sure if you shoved the decibel meeting into the intake or exhaust it would read above 80dBa on any motor vehicle.. except maybe a hybrid?
Quick Reply: ticketed for exhaust being too loud...
