Ran a LP560-4 last night
Old 04-10-2009, 02:24 PM
microboby's Avatar
microboby is infamous around these parts
It seems that all the moding makes not a big diference in power , It might make it on the wallet but when its time to prove against something it might just show us the truth.
I have always had doubts about all the high priced packages for the 996TT that advertise 550+,600 or whatever HP. maybe that is the reason I still keep my car stock. Such is life
  #32
Old 04-10-2009, 02:35 PM
Szpet's Avatar
Szpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud of
Buy or borrow a driftbox and you will get the true answer.
  #33
Old 04-10-2009, 02:51 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Before you you guys are so quick to compare hp to hp, you might look at weight and gearing also?
  #34
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
I have also have the 2c setup, I had traction issues during tuning and would spin the tires in 2,3 and sometimes 4th at about 4500rpm while doing 2000-redline WOT runs. I swapped tires to something with more grip and can still break them in 2 and 3rd easily ...but I am at over 6000', you should *easily* be able to do this at sea level. The 2c (K24/26) kits are detuned for 600whp- Have you talked with Kevin yet?
Originally Posted by kcphuah
Prche951, I have no tractions issue, nor I was spinning tires and the clutch is holding up good. And I am running the tune file as it should be. Hmm, based on what you told me how I should walk away from the LP, was that your personal expeience?
Ken
  #35
Old 04-10-2009, 03:13 PM
ttboost's Avatar
  #36
Old 04-10-2009, 03:36 PM
kcphuah's Avatar
kcphuah is infamous around these partskcphuah is infamous around these parts
Guys, thanks for the comments. Kevin is helping me with this to find out if there was anything out of line and in fact I am meeting with him tommorrow. He has been a great help since day one I dropped off my car for him to work on.
  #37
Old 04-10-2009, 03:40 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
keep us informed... I think we would all like to see the results
  #38
Old 04-10-2009, 03:48 PM
ttboost's Avatar
Yes, please. If you in fact have 600whp, spanking that Lambo shouldn't be much of a project. If he is stock, he should pull you by a car or so and then you should pull ahead and stay there ever so slowly pulling away.
  #39
Old 04-10-2009, 03:53 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
You must be the new guy.
  #40
Old 04-10-2009, 04:10 PM
Divexxtreme's Avatar
Originally Posted by Tuskir
It is what it is. R&T got 129.5mph, C&D got 130mph. Here is another one:
http://www.caranddriver.com/content/...rdoLP560-4.pdf
The slowest time I've seen was 11.4 @ 127mph from motortrend:
http://www.motortrend.com/roadtests/...est/index.html
What is a 1/4 mile time for a 600whp 911? Isnt it also around 11 flat @ 130mph? 3 car lengths sounds like a lot, but it is only a few tenths difference in the 1/4 mile...
My car with only 580 whp went 10.6 @ 136. A TT with a true 600 whp should do that or better.
The fact is; a full-weight, 600 whp TT, with stock gearing, is a mid 6-second 60-130 car. A stock weight, stock geared LP560 is a high 7, low 8-second 60-130 car.
Thus, either the TT is not making a true 600 whp, the Lambo is making 100 more HP than stock, or the driver of the TT did not drive his car properly.
  #41
Old 04-10-2009, 04:18 PM
You could not be more wrong, my friend.
  #42
Old 04-10-2009, 04:38 PM
Prche951's Avatar
Ken, Kevin will fix it for sure. I think two things are happening here. First, I think you're starting your rolls early in the rpm band. 3rd at 40 mph is not good. Unless you have 22 inch diameter wheels that is Second, I don't believe you are putting down 600 whp. Say an LP560 puts down about 460-470 to the wheels, and say that due to it's dual clutch tranny you give up another 50 whp, you still have enough to walk him. The fact that you are not spinning your tires tells me that there is no way you are at 600 whp. I'm at one level down from you, due to lack of fueling and I am spinning tires (PS2's) in 2nd and part of 3rd.
Once Kevin gets it all sorted out, run him again and lets see where things fall.
  #43
Old 04-10-2009, 04:47 PM
GT3Ranger's Avatar
GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !
As has been said, things do not add up here.
I will say the LP-4 560's are wickedly fast. I was at the dragstrip Wednesday night and there was a white LP-4 560 (stock as per the owner) and he was running 11.1 to 11.3 sec passes and trapping 127-8-9.
We've also had highway runs with the 560 against our nitrous set up E60 M5's (580 - 585 rwhp) and get beat buy 2 carlengths consistently.
The LP-4 560's got something special because they're alot faster than the rated 552 bhp.
Ranger
  #44
Old 04-10-2009, 04:51 PM
heavychevy's Avatar
Originally Posted by bbywu
Isn't the LP 560-4 about 3300 lbs?
I was just going based on the weight from the mag that posted the 129.5 mph trap speed. If it's 3300 lbs, that makes a lot more sense then. But not nearly enough sense to beat a 600 whp car. We are talking 680-690 almost 700 hp in a TT vs a stock 552 hp LP. There is no way he should get walked.
  #45
Old 04-10-2009, 07:03 PM
Tuskir's Avatar
Tuskir has a spectacular aura aboutTuskir has a spectacular aura about
I think part of the problem is that nowadays everyone with a garage is suddenly a "Porsche Tuner". There are only a handful of established tuners that I would trust, such as Ruf, Evoms, Protomotive, and a few others. As I understand, this particular car was tuned by Vivid Racing and I'm just not convinced they are up there with the best. And when you're up against a wickedly fast car like LP560, your tune and hardware better be at 100%, which I don't think was the case here. Even according to OP, his car was making low power after the kit was installed:
https://www.6speedonline.com/forums/...ectations.html
Quick Reply: Ran a LP560-4 last night
