Cant get into 2nd, 4th, and 6th Gear
Hi. This is different from the "I can't get into first third or fifth" thread...because I can't even physically shift into the gears. About last week, the gears(just the evens, odd gears and reverse work perfectly) began to get harder and harder to shift into(like, sludgy feeling), but then it went away kinda, so I paid no attention to it. Today after getting off the freeway, it started up again and got real bad. I physically can not shift into any of those gears without using 2 hands and pulling back HARD. Anyone have any idea what the problem is? Is it just the shifter linkage? Will I need a new shifter or is it something worst....need info ASAP!
My car:
2002 Porsche 911 Turbo
Just turned 50k
EVOMS stage 1 (reflash, intake, divs)
Unknown short shifter(previous owner installed)
My car:
Just turned 50k
All I can tell you is that you can F your tranny by forcing it... assuming it isn't already hosed.
You problem can be shifter, shifter linkage/adjustment, or transmission shift forks.
If it were mine I'd take apart the shifter and re-install the SSK, checking all alignment.
Do Not force it...drive in 1, 3, 5 if need be.
A
A
I agree. I would take the cables OFF the shifter and let them sit where they normally would. The cables are sprung in and out, they will sit in the "halfway" position. Make sure the shifter handle is PERFECTLY straight up and push the cables BACK into the shifter and make sure the plastic sprung pieces click into position. Then try it.
Hi,
I know this is an old thread...but did you find out what was the problem? I am also currently facing the same issues with 2/4/6 gears which are very stiff engaging/disengaging. 1/3/5/reverse are smooth and easy to engage.
regards,
colin
regards,
colin
My car:
Just turned 50k
My car:
Just turned 50k
calexand
11-05-2015 01:05 PM
10-06-2015 06:13 PM
