Are TT and GT2 suspension/brake assembly mounting points the same?
Old 04-13-2009 | 11:41 PM
Daniel's Avatar
Daniel is infamous around these parts
Is it possible to put all suspension/swaybars/brakes from a GT2 onto a TT?
What are the differences between the two besides PCCBs?
Old 04-14-2009 | 06:47 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
No. but there is hope. Call Moton and get some sleeves. The Moton suspension is the same for the TT as it is for the GT2 except for a sleeve that prevents the struts from sliding thru the upright. You'll use this on the OEM GT2 suspension struts. You also might need an extra locking ring or two.
You'll need new sway bars drop links, but you can use the sway bars. Call Vivid and pick up some Agency Power rear dogbone sway bar drop links, and get the front sway bar drop links that relocate the pick up point from the strut to the upright bolt. Dan will know what you are talking about.
Mikelly should help answer your question about the brakes, otherwise check his sticky thread on brakes.
Good luck,
Ryan
04-28-2022 12:38 AM
carwash
09-26-2015 03:11 PM
orbelo
08-30-2015 12:26 PM
ECS Tuning - VW
08-28-2015 11:10 AM
Quick Reply: Are TT and GT2 suspension/brake assembly mounting points the same?
