How much are you paying for an oil change at the dealer?
#31
What pan do you have thats big enough to hold all that oil, yet fit under the car on the ground?
#33
I have this 5 gal one from Autozone, It has inverted lips on the inside discouraging "gush over". If you're kind of prissy about drips on the floor, they have a pan to go under it too (25x36x 3/4).
I hate clean-up but I haven't had much of a spill since I bought the big yellow one. Some guys just drive the car up onto lengths of 2x6, I like to jack mine up all the way so I can inspect all the parts under there & check for leaks after the change. Kevin at UMW recommends removing the fuel pump fuse so the oil pressure comes up before the engine fires up.
#34
That yellow one is the one I use for coolant, I have a black one just like it for oil. I never thought it would fit under the car though...have to try it.
#35
I use a 10 Qt. Black one from Autozone. Its a tight fit under the car but it works fine. I access the oil reservoir from the side of the car behind the right rear tire. Don't pull the drain plug as the oil flows too fast. I unscrew it almost out so I can control the flow. Once the flow is down to a trickle I remove the plug. The engine block drain and the turbos can be accessed from the rear of the car and I use a standard 5 Qt. dish type to catch that oil. The only thing that gets dirty is me laying on the floor.
#36
I jack my car up, the yellow would be a tight fit
#37
#38
The pan (tub type) I bought has a slip off plastic grill on the top to prevent the plug from falling in. Also has a capped drain plug on the side to dump transfer the used oil to whatever you are using to dispose of it.
#39
This one?
pshep138
09-01-2015 09:45 AM
