SOMEBODY got new GRILLS!
#31
https://www.6speedonline.com/forums/...eens-pics.html
My first question are why did you use screen that is so large? If your objective is really to keep crap out, then you should have used the small, black, powdercoated diamond mesh from the same vendor. See the pics in my link above and note that even small butterflys are kept out. Secondly, why mount the mesh so that the diamond patern is vertical? It doesn't match the lines of the plastic grill nor the shape of the front of the car. Lastly, I understand you zip-tied the center grill to the rubber boot in front of the radiator. Now you won't be able to get to your radiator easily (even when you remove your bumper to clean the crap out--w/ vaccuum or whatever) that will come through your large screen. I guess you will have to cut the zip-ties, remove the screen and then reinstall.
I am being very critical here only because I've recently done a lot of thinking on this subject and designed and installed what seems so far, to be a great solution. I drove 175 miles yesterday in 85-90 degree heat with no temp problems (and you should see all the crap my small screens kept out of my radiators).
Any thoughts on a comparison appreciated.
#33
dt I'll measure the stuff when I get home but I can tell you that this stuff was so small that we had to use a dental pic to pull the mesh into place
Also mounting it to the rubber isolates it from the plastic. What of you eventually have the stuff work loose and vibrate? Mine did and cracked the grill. Removing the grills if you want to clean out the openings is quick and painless
Sorry our installed didn't meet your approval, but it worked for us!
Mike
Mike
#34
Good job Mike.
Our tech named Mike has done about 4 cars this week with the mesh. it really looks nice.
#37
Mike
Mike
My way's better, my dog is better than your... etc., etc.
#40
Paulie, You're killin' me man!
DTMarsh, There's a lot of ways to skin cats man...
This is the size of the mesh we used and it was indeed the XXL, according to Larry's receipt, which I have...
If yours works for you, then great... We tried a permatex sealer type stuff and then some black calk, and both were goopy messes... We were able to attach the grills the way I described in the write up without any fuss, muss, ore mess... Works well actually and I'm very happy with the results... I'll take more pics and we'll revisit this after I'm done getting some paint on the new bumper cover!
Oh, and my wife is much, much hotter...
Mike
Mike
#41
Mike,
Somebody recently posted a GT3 DIY on Grill Screens and commemted that they got the XXL size for Cust Car Grills and thought it was too big. Just a preference thing. One of the reasons I went with small is that you said you had no problems w/ your previous mesh size that was rather small and that I had asked you about some time ago.
With my permatex process I'll grant you that you have to be very careful and the screen mesh must fit PERFECTLY, i.e., cut from a template.
I'm looking forward to your pics and some more discussion.
#42
David, Yea it "could" be smaller, but Larry already bought it, and it honestly didn't look that big to me... My stuff was MUCH smaller, and filtered out a lot more stuff, but his is WAY THICKER and stronger... I guess it's probably a trade off... I figure with the OEM grills, the screen mesh included in the mix, you'll keep tons of stuff out that would otherwise get trapped... It's kind of a trade off though. This stuff is thick though!
Mike
Mike
#43
Actually, I'm jealous because I did mine by myself while you obviously did yours with Mike who also has a passion for these cars. There's nuthin better than playing w/ your car and making it better with someone who knows as much or more about it than you do. My car makes me grin everytime I drive it, but the relationships I've created since owning my turbo are priceless.
#44
Mike
Mike
