How to remove headlight lenses
Old 04-22-2009 | 05:35 PM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
I want to remove the headlight lense.
Anyone here know how to do that?
Old 04-22-2009 | 06:44 PM
Slow4s's Avatar
Slow4s has a spectacular aura aboutSlow4s has a spectacular aura about
They do not come apart and if you try, you will wreck the seal.
-Alex
Old 04-22-2009 | 06:47 PM
SXN's Avatar
SXN
I've seen some guys paint the inside of their headlights.. so I assume there's a way to do this??
Old 04-22-2009 | 08:59 PM
ixotuckeroxi's Avatar
ixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to behold
joey mod in the mini cooper world consists of using a hairdryer on the seal around the headlight and breaking the lenses apart with a screwdriver. once done, using a primer and paint to cover the areas and then putting the lights together again. at this point, throw them in the oven and let them bake for 3-4 mins at 300 to reseal.
apply as you will...
i did them to my mini and had initial problems with the paint flaking off because of the heat from the xenons. after doing this several times, i just took the lights to maaco and had them shoot some color and resealed as mentioned above. no issues since.
Old 04-22-2009 | 09:10 PM
grandpa's Avatar
grandpa is infamous around these parts
most other forums call for throwing the headlights into the oven for x minutes at xxx degrees until the seal is rendered pliable. often times, however, this may lead to moisture intrusion as a result of a less than successful reseal.
not something i would want to do for myself.
Old 04-23-2009 | 12:01 AM
Slow4s's Avatar
Lol, that sounds so ghetto to roast your headlights in the oven,
Old 10-18-2009 | 03:45 PM
The Youngn's Avatar
The Youngn is infamous around these parts
Old thread but I have taken apart my headlights and painted the housings black on my Cayman. Couldn't use the oven as the heat had no effect on the seal.
Old 10-18-2009 | 03:58 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
can you explain how you did it then for people who may also want to do this (i dont plan on doing it, i dont think its worth it for a silver car but maybe on darker cars it is worth it)
NIKAS
08-20-2019 08:53 PM
markj
911
04-07-2016 06:44 PM
XLR82XS
10-05-2015 08:02 AM
MC36
Southeast
09-01-2015 07:39 PM
Quick Reply: How to remove headlight lenses
