Need help - brake duct install
Old 04-25-2009 | 09:11 AM
boss351's Avatar
boss351 is just really niceboss351 is just really niceboss351 is just really niceboss351 is just really nice
Exclamation Need help - brake duct install
Putting some big 996 GT2 brake ducts up front, everything else there is stock. Suncoast stopped stocking the GT3RS ducts (not sure why) but these are very similar in size.
Looks like I will need to trim some plastic off both front and back ends to make it fit.
Anyone can confirm exactly where and how much they trimmed and have any close up pics installed etc?
Old 04-25-2009 | 10:37 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
You don't have to trim anything on the duct... what I done was make a slit in the plastic (think it is part of the undertray, my car is not here at the moment) you are only making a slit 2 or 3"... I then made another tiny slit for a cable tie to attach duct and undertray together (see the hole in the right hand side in your pic of the duct)... hope this makes sense.
Just remembered something else, you might have to take a small nick out on the left hand side on your pic... it sits very close to a ball joint.
It's difficult when I don't have the car here!
Old 04-25-2009 | 10:40 AM
boss351's Avatar
Yes, making a slit was what I thought was going to be needed in the right (front side). Thanks.
Anyone else though with pics would be greatly appreciated.
Old 04-25-2009 | 07:43 PM
boss351's Avatar
I ended up trimming a little off the end closest to the rotor, otherwise at full lock inwards it was pushing and buckling the duct. Also slit the other end and it slots in place nicely with the under tray plastic:
Now just wish they were cooling some PFC floating rotors!
Old 04-25-2009 | 11:15 PM
oak's Avatar
oak
I just notched mine. If you are going to the bother switching brake ducts you might as well change out the backing plate or atleast trim the plate to expose more of the rotor.
Seems like changing out the ducts won't make much sense with out modifying the backing plate for more of the rotor to get fresh air.
It might prudent to add some zip ties to your ducts too while your under there.
Old 04-27-2009 | 09:22 PM
j.mitchell70's Avatar
j.mitchell70 is infamous around these parts
Just installed a gt2 front end. Need to finish up and install these as well
Old 04-27-2009 | 10:45 PM
audikp's Avatar
audikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to behold
I installed the GT3 ducts and didnt have to cut them at all to fit....
Old 04-28-2009 | 01:16 AM
oak's Avatar
oak
those are completely different ducts.
the ones with the rivets are cup ducts they are larger and longer. the front edge needs to be trimmed slightly.
Old 07-17-2009 | 04:51 PM
StevoRocket's Avatar
StevoRocket is infamous around these parts
Cup ducts are vunerable to damage by road humps and driveways as well as roads with lots of curvature.
Suncoast probably stopped stocking the 996 GT3RS ones because nobody bought them at about 200 dollars a pair! (no 996GT3RS in the USA)
Old 07-17-2009 | 06:41 PM
landjet's Avatar
Now you need to pick up the rear ducts that Suncoast sells.
2lflat4
11-18-2019 06:05 PM
ECS Tuning - VW
08-20-2015 04:07 PM
TrackOne
08-20-2015 01:56 PM
Quick Reply: Need help - brake duct install
