On dyno, which gear is usually used?
Old 05-02-2009, 12:36 AM
kcphuah's Avatar
kcphuah is infamous around these partskcphuah is infamous around these parts
Some said 3rd gear run, some claimed 4th gear run is more accurate to measure. So, which is more commonly used?
And also, what is the dynodynmics correction factor is from wheels HP to crank HP?
Thanks in advance.
Old 05-02-2009, 01:38 AM
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Generally the gear closest to 1:1 --in standard T box this is 4th gear.
Old 05-02-2009, 06:57 AM
Prche951's Avatar
Thanks in advance.
4th is closest, and as for correction factor, who knows. Have you had any stock 996tt's there. to calculate back to 420bhp based on what they produced on that dyno?
Old 05-02-2009, 07:02 AM
ixotuckeroxi's Avatar
ixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to behold
+1
on every car ive had dynoed, it was 4th.
Old 05-02-2009, 09:13 AM
kcphuah's Avatar
Hmm..I know a friend with just an upsolute chip makes 365whp on the dynodynamics. But how many hp is upsolute tuning suppose to give??
Old 05-02-2009, 09:37 AM
Prche951's Avatar
that's why you need to get a stocker. who knows how much the chip gives..
Old 05-02-2009, 09:46 AM
kcphuah's Avatar
On upsolute site, it says stock 420hp and chipped 510hp. Based on that, the correction factor is 40%?? That cannot be right.
Old 05-02-2009, 11:56 AM
Prche951's Avatar
I would not use what they say, too many factors. You have to use, the factory rated bhp on a stock car compared to what it did on THAT dyno. otherwise it is irrelevant. Also, you need to do it for a stock 996tt, because losses will be different on model changes.
Old 05-02-2009, 01:45 PM
justatoy's Avatar
justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !
This may be a dumb question but:
what would happen to the rwhp numbers IF the dyno run was done in 3 rd gear?
Do the numbers get better?
Stacy
Old 05-02-2009, 02:12 PM
Prche951's Avatar
Stacy
I think they need to do more correction factors which gives you even more errors. Dynos already have lots of correction going on and this just adds to it.
Most people use dynos as an upgrade comparison. They will dyno stock and then dyno after mods to see what improvement they got.Other than that it really isn't too useful as some dynos are too conservative and others are to liberal.
Old 05-02-2009, 06:15 PM
ttboost's Avatar
I think my tuner uses 3rd to dyno. If you baseline in 3rd, make ALL your dyno runs in 3rd. As 951 said, it's just the changes/improvements your looking for, so why do 135mph on an dyno!!!
Old 05-02-2009, 07:01 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Usually 4th is used because it is a 1to1 gear ratio.
Old 05-03-2009, 07:54 AM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
For your reference my car with EPL flash alone (everything else bone stock) made 400 whp and 480 Tq on a Dynodynamics Dyno. A stock car made about 330 whp on the same dyno.
Old 05-03-2009, 10:09 AM
Quantum's Avatar
Quantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond repute
Thanks in advance.
4th gear like said is the closest to 1:1
In regards to the correction factor I believe if you are rwd it would be 8% and if you are awd it would be 14%.
Old 05-03-2009, 10:47 AM
kcphuah's Avatar
so, the concensus is 4th gear pull for the closest gear ratio. What about elevation, could that be a factor to higher or lower reading?
Quick Reply: On dyno, which gear is usually used?
