How much power can the 996TTs make using 91 Octane
Old 11-18-2009, 04:40 PM
Prche951's Avatar
Originally Posted by robertp
Revo does not allow you to set an exact PSI/BAR setting. It has its own value settings (1-9) and they represent changes in the ECU. I had the boost set at 8 and that, in turn, allowed the motor to be boosted to 1.1 bar with the stock exhaust. Once I changed the exhaust, to a less restricted model, the actual boost raised to 1.4 bar so I had to lower the value to 7 (or 1.2 bar).
ok, got it. pretty cool setup. How does this affect the ecu's safety protocols? Reason I ask is usually you can change exhaust and it might increase boost a little but not by the drastic amount you saw, which indicates an override of ecu safety functions possibly.
  #92
Old 11-18-2009, 09:10 PM
BLKMGK's Avatar
My boost raised from 1.1 to 1.4 when i went from a stock exhaust to the JIC w/200 cel cats. I had to lower the boost back down to 1.1 - 1.2.
That sounds like the OEM exhaust was pretty restrictive. Considering it also doesn't drone and is quiet i think that pretty much confirms it! I'm betting that with the new exhaust the turbos spooled up much better too right? that too is a sign that the exhaust side was restrictive. Turbos really hate backpressure in the exhaust...
  #93
Old 11-18-2009, 09:13 PM
Prche951's Avatar
yes it is very bad. there is a diy on how to make it much better by drilling straight through and using the mufflers as resonance chambers
  #94
Old 11-18-2009, 10:00 PM
BLKMGK's Avatar
Yup saw it and had to chuckle. Hey if it works and doesn't drone it's worth considering. I'm NOT proud when it comes to saving money or making power!
  #95
Old 11-19-2009, 05:35 AM
Prche951's Avatar
actually, I think that would work well. I would even drill out the cats and make it even more free flowing.
04-28-2022 12:38 AM
turbotuner20v
09-11-2015 12:02 PM
Sales@epl
996 Turbo Vendor Classifieds
09-07-2015 02:05 PM
Quick Reply: How much power can the 996TTs make using 91 Octane
