Trailer Brakes, Surge or Electric?
Can anyone explain the pros and cons between surge and electric brakes on a trailer. Is one better than the other? Does one require any more or less maintenance?
I am looking for a trailex trailer and would like to get some feedback as to which way to go.
I've used both, and I presonally prefer electric brakes on a larger combo rigs... My current setup is over 20K pounds w/ truck/ trailer/ car/ tools/ essentials. That said, I know a number of guys using the trailex trailers in both configurations... Surge brakes work off a lever mounted to a cable in some cases, and to a plate the ball rests against in others, and it applies brakes based on the level of "surge between the tow vehicle and the trailer/load. The electric brake setup applies brakes based on the elecrical system in the truck or the electronic brake box that is an add on to balance the two systems...
With a trailex trailer being so much lighter, you can't go wrong. If I had it to do over again, I'd have gone the enclosed trailex route.
Mike
Mike
I would love to go enclosed but financial and storage constraints limit my choice. I am leaning towards the surge as no further work needs to be done on my tow vehicle. Also I plan to have the trailer longer than the tow vehicle as it is leased and would need to switch the electric controller and wiring.
As far as reliability and performance does anyone know if there is a difference between the two?
I just installed a VERY cool electric brake controller in my tow vehicle. They control electric brakes but act like surge brakes.
The problem with electric brakes is that the second you hit the brake pedal in the car, the trailer brakes start ramping up to your preselected % of power. Even if you are only coming to slow stop.
The module I just installed has an accelerometer built in. You can set the electric brakes at 60% but when stopping slowly, they only ramp up to 20 or 30%. Hit the brakes harder and they ramp up to a higher percentage. Very cool.
Maybe this is well know to some of you but I had never seen one like this.
Got the module at Autozone for $89.
I have the surge brakes on my Trailex (6+ years) and have been very happy with them. The only real issue that I know of is that if you try to back the trailer up an incline, the surge brake will resist, maybe even locking the trailer wheels.
Jon
Jon
Jason, Do you have a brand and model number for this unit??? Mine has been clicking and making a little noise as of late...
Mike
Mike
I use a Tekonsha Prodigy to control my electric brakes in the trailer. (F250 4x4PSD with a 14k lb(max) gooseneck trailer)
The unit has an accelerometer in it, so it uses a combination of variable to control the brakes. (The accelerometer measures how much the tow vehicle is actually slowing once the brake are applied and generates a deceleration value.) You can set overall brake force, but also adjust how much of the deceleration variable that is added in. You can get really phenomenal control with these (I assume there are others on the market now, mine is a few years old.)- to the point that the braking feels almost neutral: so the trailer doesn't seem like it is locking up, nor does the tow rig feel like it is being pushed.
FYI
http://www.brakecontroller.com/
Edit: My truck had basic wiring in place for this, and a custom harness was available to just plug it in!
FYI
I have both; surge on the boat electric on the Trailex. The Electric units require a little more set up wiring Etc, but they are well worth it .go with electric.
I use an inexpensive computer controlled box. work s fine for the light Trailex. If you go with heavier loads than an inertia type might be better.
Elliot
Elliot
ModBargains
997 Vendor Classifieds
10-13-2015 04:53 PM
ModBargains
996 Turbo Vendor Classifieds
10-13-2015 04:52 PM
ECS Tuning - VW
09-02-2015 10:03 AM
adjust, adjustment, bra, brake, brakes, car, cons, controller, difference, electric, fast, pros, surge, trailer, trailex
