Correcting rear camber.. the right way to do it?
I think there is a trade off if you only installed adjustable upper control arms (dog bones) without adjustable toe links. You would get your camber corrected but in doing so would cause excessive toe-in and thus will continue to have inner tire wear. I think toe-in wears tires faster than a little extra camber. My plan is to install my techart lowering springs with rear adjustable toe links only.
Jon
Jon
My understanding has been that if your car is lowered 1" or more you can't get all the way back to factory toe and camber settings without adjustable toe links and dog bones but, if you get just adjustable toe links you can get toe back within factory spec and you can get camber close (a little more negative than factory). This is the route I've been advised to do. I'm still waiting for a free weekend to do the install. For me, I want a little extra camber in the rear anyway since right now my rear tires wear more on the outside but I drive fairly aggressively most of the time so a factory alignment is not what I'm going for anyway.
I am curious as well. My car ate the inner inch of my PS2s very very fast and i had it alligned to GT2 specs. It is at GT2 height now. Judging by the wear it is toe issue, how can I have this fixed?
#TeamAIM
#TeamAIM
So is THIS the toe link we are ALL talking about???? http://www.vividracing.com/catalog/s...e-p-53207.html
Or something thereabouts????
Only if you mis-algn the wheels and cup the tires. Then they will sing.
