NON VERIFIED 60-130 mph (Woodtster)
I went out to ATOMIC Z's top secret garage yesterday and filled up
my car to the brim with SUNOCO GT260 PLUS.
60 degrees, windy (it has been really windy lately)
Used my Racelogic Performance Box:
Best Run:
0-60 mph 3.8 seconds (this takes clutch abuse)
0-100 mph 7.2 seconds
50-70 mph 1.1 seconds
60-130 mph 6.4 seconds![EEK!](https://www.6speedonline.com/forums/images/smilies/eek.gif)
This run was at a peak of 1.35 bar and when I turned up the boost
slightly higher (1.4 peak) I acutally did worse (6.9, 7.0, 71.)![Confused](https://www.6speedonline.com/forums/images/smilies/confused.gif)
This is not verifed so please do not impale me.
This was done on closed roads far from the cities, professional drivers
using hans device, 5 pt harness, fire suit and good helmet.
I have heard that it is terrifying going that fast in an automobile
Best Run:
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
Not bad at all Marty, esp for on that low of boost!
Of course it's terrifying at that speed! I almost crapped my shorts when I passed 87mph (because that's when you go back in time according to Back to the Future) on my 60-130 passes
hey marty... nice times! i experienced the same thing the car would run slower on higher boost running the same fuel ... i logged it and what i found that it was pulling timing anything over 1.35 bar... i experienced this with the gtplus and the supreme 112 leaded... i ordered a 5 gal pail of the max nos stuff sunoco said it is real close to c-16 ill let you know what i find out
tim
tim
It's been my experience that the first run is usually the best and every run after that will be a little slower. The Meth helps keep it consistant though. Very nice run Marty, over half a second better, very good improvement!!!
Was this 2 shifts? or 1 shift? My best 50-70 for 1 shift is 1.21. (start in 3rd, shift to 4th) If thats 1 shift, 1.1 is VERY impressive also.
Best Run:
I have heard that it is terrifying going that fast in an automobile![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
Best Run:
What is the throttle body doing? Wondering if it is closing on you...
