interior rattles after aftermarket exhaust
Any of you guys have interior rattles after going from a stock exhaust? at about 2000 rpm all the rattles come to life... seems like passenger side door area or rear.. its driving me nuts...
I had (have) exactly the same problem....
after I changed my exhaust a rattle from the rear of the head liner got a lot worse.
I reduced the problem by inserting foam in the slot above the headliner right where it ends over the rear window.
Still not perfect - but better.
Seems there's a plate or something similar which terminates the headliner at the rear and slots into the bodywork.
It can work loose and cause a rattle which is aggravated by after market exhaust.
Tim
Tim
i've been thinking the same thing after a few thousand miles...
eventually i just try to drown it out. i've given up trying to fix every rattle in the car. the car is no longer stock so i can't expect it to be quiet like one right?
I am SOOOO glad I went back to the stock exhaust, which is raspy enough when I need it to be!
Mike
Mike
When I put the AWE muffler/cat deletes I noticed more rattles as well. Mostly the seat belts vibrating off of the door jam area. Even though it rattles, I still have a gigantic smile on my face everytime I drive it though. =)
Yeah, but wwwaaayyyy too loud!!!!
PenguiN
04-22-2021 07:33 PM
