Hoosier R6 on OEM Turbo Twists
Sorry for the double post over in tire section...no hits so reposting here.
So which pairing of tire sizes have you guys done? 245/40 and 315/30? That seems to be a good match diameter wise. My camber is set at -2.5 in front and back. Wondering if there are clearance issues on the inside...with my camber settings, pretty sure I have plenty of room on the outside
If you go with the shorter 225/40, it looks like you need the 285/30 for the best overall diameter match so am a bit befuddled. Plus, not sure I want to go smaller than stock plus want a bit more contact patch up front.
TIA
TIA
tropicatango
12-04-2015 02:45 PM
oddjob142
08-19-2015 12:27 PM
