Please help me !!!
Old 06-03-2009 | 10:39 AM
jpflip's Avatar
Brad, it is an anti pollution pump. As soon the car is started for 50 to 179 seconds an air pump start to inject fresh air into the exhaust gas flow to speed up the chemical reaction into the catalytic converter. Many cars got that feature....
Old 06-03-2009 | 10:51 AM
Brad Bedell's Avatar
Brad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to behold
Thanks! I suspected that,but seriously... a modern car with an air pump?... I'd have figured the air pump went away with the carburetor.... Sequential injection and proper tuning is where the future lies...I mean, EGR pretty much is dead with proper computer management.
Anyone looked at omitting this piece and tricking the DME into thinking it's still there?
Old 06-03-2009 | 11:17 AM
YellowmanTT's Avatar
YellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of light
Thank you to all of you gentlemen for trying to help me , I will check the relay and connection tonight when I get home. Hopefully its just a simple problem.
Much appreciate it to all of you!!!!
Old 06-03-2009 | 11:35 AM
Speedy996tt's Avatar
Speedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud of
the support on this board is unparalleled! this has got to be the best site ever, seriously
Old 06-03-2009 | 11:57 AM
I was talking with Tony at EPL, he felt that he could delete the Air pump from the DME with a flash. He was going to get back with me on this later today.
If one was going to spend $1300+ it might be worthy of doing some research as to the pro/con of such a mod when a flash is similar money.
Old 06-03-2009 | 12:20 PM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
Completely agree...
Old 06-03-2009 | 12:36 PM
rolfjahn's Avatar
rolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to behold
STOP and Read This Post
Originally Posted by junior
the code is P0491 & P0492 that's include parts and labor
https://www.6speedonline.com/forums/...ml#post2064108
I've been there and done that with other members 3 times.
This is easy to fix if the air pump is not shot.
If you need more send me a message and you can call me.
Old 06-03-2009 | 12:59 PM
jpflip's Avatar
That's interesting if he can trick the ECU. But normally you also have to had a resistance to sheat the system. Anyway I am anxious to see if it can be done.
Old 06-03-2009 | 01:21 PM
As am I. That pump is pretty big and would free up lots of room and clean things up a bit. :Especially for doing silly stuff like fuel injector and pressure bypass valve adjustments.
Old 06-03-2009 | 01:48 PM
jpflip's Avatar
I agree with you plus you are eliminating a common cause of troubles and cels light.... But I guess for California resident they are not aloud to perform any modification to this system because of the emission strict laws... Just guessing here...
Old 06-03-2009 | 01:54 PM
rolfjahn's Avatar
Air Pump/Check Valve/Engine Lowering instructions
1. How to lower the engine cradle. You must also remove the air box and watch your upper intercooler hoses.
2. The diagrams for what is what for ordering parts. I ordered from Suncoast Porsche.
Old 06-03-2009 | 03:28 PM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
i had similar codes before and it was my diverter valves, have you changed those?
You can remove the air puimp without moving the engine, check for the post DIY about how to change the fpr to a 5 bar, you have to move the pump to get there.
Old 06-03-2009 | 04:49 PM
Smile
I do currently have the aluminum diverter valves on mine , Last night I check the diverter valve everything looks good , I will be check the air pump section tonight when I get home tonight.
