Stock ZR1 does 10seconds..Video inside!!
A Z06 with intake, exhaust, tune is pushing 485-490 rwhp. That is about 550 crank HP.
Not sure. I think they were from 2nd to 4th, which is around 140 mph. Apparently the ZR1 owner wasn't too happy.
Another nice video. Damn, would you have ever thought a stock ZR1 doing 10 seconds. Respectful run and indredible driver too. Enjoy.
http://videos.streetfire.net/video/1...htm#commentTop
Hopefully I'll be able to convince him to get a couple runs with me on video.
True, true, forgot about the weight difference and mods.
Great dicussions guys. But I think at higher speeds ZR1 will pull away from Z06 stock. High HP shows more at higher gears. Crazy though that bone stock Z06 has better times at 1/4. After I'm done also, I have one race set with a ZR1 also
It will absolutely pull away from a stock Z06 at higher speeds. Especially considering its close-ratio 5th and 6th gears. But a bolt-on Z06 will still give it a heck of a run up to 140 mph.
This beast right here:
Has slayed many of it's own kind, but I'd be interested to see how a ZR1 did against Matt's car on motor.
Good question Walnut. I think the ZR1 and 996tt weigh about the same. I don't know which one has a lower cd nor do I know which has better gearing. I do believe that both are producing around 650 crank hp and that an awd Porsche may have an advantage out of the hole. It seems that the 18gs have been trapping a few mph faster but then that's the first and only ZR1 I've seen run so far.
