EVOMSit GT900+Torque Monster.. Shakedown 60-130 data. Good News/Bad News
First of all I would like to apoligize for the tardiness in producing numbers. I took possession of the car last evening at 8PM PDT and got my first numbers at 3AM the next morning. BS I know, there is no reason why it should take 7 hours to get a time.... Anyway, I put the car on my trailer and took it out to the AZ desert west of Phoenix. The bad news is I tossed my serpentine belt and only produced one run. The good news is it did a 5.56 on its maiden run. Considering the corner balance weight of this car is approaching 3800 lbs,lets call her Porkey. Porkey was a handful this morning to be sure. I took the car out and did some quick pulls to warm it up, did a bunch of 50- 90 type runs to get a feel for the car. I pulled over to pull the SD card and put it in my laptop to make sure it was logging properly,it was. Tried a 2-3-4, didnt happen. Street tires and near 900 ft lbs at the crank was not a very good combination. 3-4 was a bit better with an even pedal. I said it was going to get posted, good or bad, here it is....5.56 2 degrees down.
What do I think of this? Well, considering the fact it was the first time out in several years in a car that has more HP than my 200hp A3. It weighs in at near 3800lbs, is still AWD, has no weight saving measures,only running 105 octane and is on street tires in the AZ desert... I am pretty happy. Do I think this will be a sub 4sec car at this weight? Nope. I do think once I feel more comfortable in the car and get my DRs on it should be a solid 5.2 I would think.
The car is going back to Todd today and they will look at it Monday to make sure the pulley alignment is OK and replace the belt. I do appreciate Todd meeting me on a Sunday to take the car in the shop. Heck, I texted him at 3:30 this AM and said there is nothing serious wrong but could he call me when he gets up....yup, he called at 3:35. I am definately filling out this customer service survey!!!
Kevin
That is a very impressive run especially considering it was your first time, I am certain it was hot (which is a huge killer in times), your weight of you car, the lack of traction (tire pressure or different tires?),a new clutch? and faster shifts etc.... It is hard to get below 5 sec and extremely difficult to get below 4.5 sec. These are huge barriers to break, for example I have watched several high HP cars run several runs back to back to get into the 4s.
Congratulations
Robert
Congratulations
Robert
Very impressive Kevin!
She makes good power that is for sure.
BTW, were you thrilled to death to finally drive it?
Congrats!
MK
Congrats!
MK
I respect a 5.56 a LOT more than a 900 hp claim. 60-130 tmes, trap speeds, road course and mile times are what REALLY count.
This car should indeed run a very low 5 second time w/ cold weather and DR's. Good job!
I know that is a long story, but can you break down and summarize what is in your car?
I just realized, as an SME, do you send the file to yourself?
Kevin, SWEET NUMBERS. Easily a 4 second car IMO. My 60-130 dropped 1.3 seconds by converting to RWD and 36 additional pounds of weight. I'm guessing you can easily knock off .6 seconds by putting her on a diet. You still have C16(which I vaguely remember you not wanting to use) and cold air to help.
Never mind, I found it:
Red, it was in their shop about 16 days I think start to finish. Timeline was just fine in my mind!
Fuel system: EVOMS Frankenfuel in tank twin pump setup with dual 044 units, Bosch relay. Upgraded fuel line, stock return line, EVOMS rails. 83lb injectors. Stock FPR
Turbo/Exhaust: Tial Hybrid GT3076R Alpha with custom billet compressor wheel,watercooled, Switzer exhaust with full cats and 02s, EVOMS race style flat collector headers with 47.5mm primaries
Tuning: EVOMSit
Intake: RSS 75MM plenum, 75MM TB, EVOMS side plenum, ported and port matched intake runners/injectors blocks, Stock Y pipe, EVOMS custom MAF housing, Hitachi MAF, Sportec twin snorkel CF airbox, BMC filter, Forge DV, EVOMS boost hoses
Heads: Custom heavy port on turbo heads, larger Ferrea intake/exhaust valves, 9K springs/retainers. Flow numbers on avg 33% better than stock.
Cams: custom exhaust grind, intake stock
Engine: Ceramic coated piston crowns, moly coated piston skirts,moly coated wristpins, flycut crowns, Arrow rods,ARP studs, EVOMS MLS head gasket, GT3RS crank,crossdrilled, shufflepinned case, boattailed mains, extra oil galleries drilled for crank center mains, Porsche motorsports bearings, GT3 oil pump, all rotating parts from the crank pulley to the pressure plate and everything in between balanced within less than a gram.
Trans/clutch: 8 Puck Clutchmasters disc, upgraded Sachs pressure plate, LWFW, associated rattles and whines, stock turbo hydraulics,stock trans
Misc: EVOMS 300M axles, B6 IC's, 6 Piston GT3 350MM brakes, Zeitronix-Boost; EGT;AFR;Pyrometer, 997 shifter, GT3RS solid motor mounts,optima 925, GT3 seats, Teq bar, bone stock exterior.....Still AWD
W/ AWD (won't it break at these powere levels?) you will hook 100% w/ R comps, I recommend the Nitto NT 01's.
Tuning: EVOMSit
I am now a Porsche Diagnostic Guru... I am not even going to wait for Todd or John to diagnose my car, I can definatively say that the serpentine belt works substantially better with a crank pulley attached to the crank! Ok, who needs my diagnostic services?
No, I am just touching myself at the moment....Scott got a copy of the file, it is his sandbox after all.
As for the AWD, who knows if it will last. I have not seen any data that definatively points in either direction. I know the dyno is rough on the diff and I think we did 40 pulls or so...I think
