Strange engine noise
Old 06-09-2009 | 01:52 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
I recorded a video of a cold start up without pressing the throttle so to hear the sound...as you can hear it goes away after 30seconds...opinions?
http://www.youtube.com/watch?v=Y7VdWIjOW08
Old 06-09-2009 | 01:54 PM
vividracing's Avatar
lifters and once the oil pressure builds it is non existant... pretty standard I think?
Old 06-09-2009 | 01:56 PM
Originally Posted by vividracing
Are you sure it is not the RC60lb injectors? They are much louder.
Hello there Dan...Its been a while...hope you are ok my friend...No iti is not the injectors,they were installed last September and the noise started ten days ago...hear the video to tell me your opinion...
Old 06-09-2009 | 02:00 PM
I rewatched it, it is a lifter I think. Do you get a puff of white smoke on start up too? Definitely not a rod.
Old 06-09-2009 | 02:05 PM
No my friend...No smoke at all...Only one time out of 1000...I believe it is a lifter...it goes away and the car runs fine...
any other expert to see the video to share an opinion?
Old 06-09-2009 | 04:51 PM
Guys...please have a look at the video to tell me your opinions....
Old 06-10-2009 | 10:08 AM
sennaforever's Avatar
sennaforever is infamous around these parts
it sounds OK to me, I say next time use this oil: Total Quartz Energy 9000 5W40 (used to be ELF)
Old 06-10-2009 | 02:45 PM
Never heard of that...I will try to find it here...i had good opinion about mobil 1...but now...Do you use it in a 996TT?
Old 06-10-2009 | 02:47 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Skandal, sounds like an exhaust leak..
Old 06-10-2009 | 02:59 PM
raineycd's Avatar
That is what I thought last night! I just couldn't figure out how to explain why it went away after 30 sec. They usually stick around...
Old 06-10-2009 | 03:18 PM
I ll go and jack the car next days to see what is going on...It might be an exhaust leak...or a header leak...and as it gets hot the leak goea away...possible...
Old 06-10-2009 | 03:45 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
sound like headers gasket leak.......
Old 06-10-2009 | 03:58 PM
Wheb i got Fabspeed headers they were supposed to have new gaskets in the box...But they did not...so i put the stock ones...but its 5 months now...and the noise started 10 days ago...Tomorrow i will check it...
Old 06-10-2009 | 11:14 PM
I got '01 TT, you should be able to find that oil in Europe since it is made in France, you should definitely try it out.
Old 06-11-2009 | 12:13 AM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
its def not a rod ... a rod is much deeper than that.. i would say sticky lifter or a slight exhaust leak that is sealing up after the head and exhaust manifold heat up and expand... has the sound gotten any louder in the last ten day or is remaining consistant?
tim
Quick Reply: Strange engine noise
