trying to reduce exhaust noise/drone
its not an exhaust rattle.... its the tone... some drone.. I cant be the only one with aftermarket exhaust that thinks its a little too loud... my gallardo with a tubi was loud, but a different sound.. higher pitch that was not too bad.. maybe because this car is a TIP, it sounds louder
Now that urethane bushing concept sounds like a great idea!
anyone tried it?
I've been thinking of fabricating some kind of removable/adjustable tip silencer. I'd like to hear thoughts on that.
Bob
anyone tried it?
Bob
Instead of adding 50lbs to the backside of your car with dynomat (you already have like an inch padding under the rear carpeting), maybe consider a different exhaust system... there are definitely systems with much less drone.
dynomat will do nothing for this. I used to install that in all of my cars for custom audio.
If you want to try however it is simple to install and you have pretty easy access to the rear shelf for a DIY.
good luck
good luck
I have switzer exhaust.. I love the exhaust.. not going to change it.. was just trying to make the cabin a little quieter... if I cant.. not a big deal.. it was just something I wanted to try...
As the others said..switch exhaust...or turn up the music...LOL
does anybody know how a ceramic coated exhaust systems work as far as reducing drone? At least you have a coupe, my cab is very loud drone
![EEK!](https://www.6speedonline.com/forums/images/smilies/eek.gif)
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
Mine is a tip (with exhaust) and I have exactly the same issue. Fortunately, it only happens in the range of 2300-2500rpm with light throttle application in that zone. Given the fact that I am a new turbo owner, you can take a guess as my "practical" solution for that problem. ![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
Curiously, getting the car serviced for the first time reduced the drone, as did getting a BMC air filter. My buddy just got the cargraphic exhaust on his tip and has no drone whatsoever. I have heard the tip drones more than the 6MT for some reason. Anyone have any idea why?
after living with this cross over for nearly a year now, I have to say I love it. It sounds like an EP loud, just about 10-15% louder and I went from not being able to have a discussion in the car and having to turn the stereo up high to hear it, to being able to have a quite discussion with no problem. The drone is not gone, but is has reduced so much that I don't even think about it any more. About the only annoyance is cold start up.
![](http://i12.photobucket.com/albums/a220/Cobalt_/DSC00096.jpg)
![](https://www.6speedonline.com/forums/signaturepics/sigpic3357_8.gif)
2001 996TT 3.6L and stock ECU
what exact mufflers are you using?
