Definitive 2005 996 Turbo "S" Flash Guide
Definitive 2005 996 Turbo "S" 6 Speed Flash Guide
Or at least this is what I would like this thread to turn out to be. I am in the final stages of selecting my flash vendor. I think I have made up my mind but I would like some more info before I pull the trigger.
What I am trying to establish are the following data about any / all flash vendor contendors. Sorry folks I am an Engineer and need facts a data. I have done limited research on them as of now.
I would encourage both vendors and users who have their products that they are happy with to contribute. I would not mind betting a lot of folk (No disrespect intended) do not really know all the info about their car's flash setup other than stated HP gain.
My setup is basic stock 2005 996 turbo S 6 Speed with the following mods:
I would rather get 1 flash to cater for my goals, as opposed to getting it tuned as needed.
Here is my list current of FLASH contenders. (Could be Expanded) They are all within my price range, I am personally looking for a solution under $1500:
Please help with updated pricing, these were just got off the web.
UMW - ($1295)
Softronic - ($1549 Sale Price)
EPL - ($1299)
GIAC - ($2500 +)
Upsolute - ($699 ??? Platinum 550hp Do not know about turbo S specific)
EVOMS - ($2600 Sale Price) - 100hp, 95tq
What I would like to know is info specific to the 2005 996 TT "S". as opposed to a standard 996 Turbo.
Vendor specific Information (Thanks for Responding)
Any help would be appreciated. I will update the post as I receive the pertinent Information.
SWR
- FABSPEED MaxFlo Exhaust System
- Stock Wastegate Actuators (adjusted to 8.5 psi crack)
- Billet diverter Valves
- Stock AirBox, MAF & Fuel Regulator
UMW - ($1295)
EPL - ($1299)
GIAC - ($2500 +)
- Is the flash code different between models?
- 996 TT
- 996 X50
- 996 Turbo S
- What is the NET turbo HP Gain for the Turbo S?
- BHP
- Wheel HP
- What is the RedLine Max on the flash, Stock seems too low?
- What is the MAX Boost Pressure (Not Spikes) that the flash will deliver? (I currently get a 1 - 1.1 reading on my gauge at WOT, A/F Ratios are within spec. I would like 1.3 bar.)
- How invasive is the flash?
- Can Dealers Detect how many times the ECU has been Flashed?
- Can it be installed easily buy user?
- Can it be removed easily?
- EVOMS - X50 & S similar different from 996 TT
- What is the NET turbo HP Gain for the Turbo S With Upgraded Exhaust?
- EVOMS
- BHP ~100 HP / 95 TQ
- Wheel HP ~80 HP / 75 TQ
- EVOMS
- EVOMS
- Stock 6,750 RPM
- Flashed 7000 - 7100 RPM
- EVOMS
- EVOMS
- 1.2-1.3 bar is about the max boost pressure that the K24 turbos will put out with these components
- EVOMS
- EVOMS - Not with EVOMS Software
- EVOMS - No, Via Mail or On-site at EVOMS or Rep
- EVOMS - No, Via Mail or On site at EVOMS or Rep
- Stock BHP of 2005 996 Turbo "S"
- 450 BHP or Crank HP.
SWR
some tuners will also give you a credit or discount if you perform more mods later and then need another flash, softronic offers this so they are top of my list so far
it would be good to note the price of the flash next to each tuner as well
i have heard prices for an upsolute flash as low as $700.00, dont know much about them though and the price almost seems too good to be true, any feedback from anyone with an upsolute flash would be good
If you are actually seeing a true 1.1 bar, and that may not be a reality given the OEM boost gauge deficiencies, then you may already have a flashed car....
No it is not flashed. When my wastegates were set at 6 psi (What they were stock. I was lucky to see .8 bar. I usually see 1 at WOT, the 1.1 was probably a spike.
SWR
SWR
Remember what assume means.......
I would have thought some vendors would have responded to help us here. I did get a PM from EVOMS (THank You). I just need a lot more info on this. To me as an Electronics Engineer a Flash is an expensive option, I would just like to know exactly what I am getting. EVOMS seems to have the highest HP / TQ but at a cost. Most others average out at 65-70HP increase.
SWR
SWR
I'm the same boat as you. I have a stock 2004 turbo s cab, but its a tip. Looking into what you find. What is this wastegate adjustment you are talking about?
SWR
- 996 TT
- 996 X50
- 996 Turbo S
- BHP
- Wheel HP
SWR
Here is some more information:
- Is the flash code different between models? YES, the software coding is different between the listed models. The X50 and "S" are nearly the same but the standard (NON X50/S) model software is very different
- 996 TT
- 996 X50
- 996 Turbo S
- BHP ~100 HP / 95 TQ with exhaust*
- Wheel HP ~80 HP / 75 TQ with exhaust*
- *The stated gains include the gain from exhaust system. The OEM exhaust system is very restrictive and power gains from software alone is significantly less.
- What is the RedLine Max on the flash, Stock seems too low? The rev limit can be set from 6750 RPM (stock) to ~7100 RPM for this power application. We typically set this upgrade at 7000 RPMS
- What is the MAX Boost Pressure (Not Spikes) that the flash will deliver? (I currently get a 1 - 1.1 reading on my gauge at WOT, A/F Ratios are within spec. I would like 1.3 bar.) 1.2-1.3 bar is about the max boost pressure that the K24 turbos will put out with the present components
- Can Dealers Detect how many times the ECU has been Flashed? Not with our software
- Can it be installed easily buy user? No, either mail in or on location at one of our installation centers
- Can it be removed easily? Yes - either mail in or on location at one of our installation centers
- I cannot seem to establish what the published HP of the S is. I read 440 - 457, is that BHP or WHP? Engine HP
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
The question was - was there a difference in the software coding from the different models. There are 3 different types of coding for the USA 6-speed X50 and S models. The differences between the software variations is minimal in terms of the map structure that are changed with the software upgrade (timing, boost, fueling, etc) So, when we make a performance file for any X50/S, we use the same coding that is extracted from the ECU to base our performance software. There are virtually no performance differences between the 3 different software variations.
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Evolution Motorsports
Thanks for your detailed response. This is EXACTLY what we are looking for for each vendor. I assume my FABSPEEd Maxflo exhaust is OK.
Thanks again.
SWR
Thanks again.
SWR
You are spending way too much time and effort on something that does not matter that much. All basic flashes are about the same.
If you want a worthwhile increase in hp, you need an 18G compressor in your turbos, a 5 bar and a customized flash/tune (you will need to datalog your info and go back and forth a couple of times).
SWR
With an exhaust, you'll be at 1.1 Bar on 91 octane and 1.2 on 93 with your setup, but thats about as far as you can go before you start to get into the heavier mods (turbo upgrades).
I have the same setup as you do with the basics done. Exhaust, DV's, F-Hose, Intake.
I went with the Softronic flash because Dan at Vivid cut me a deal because I bought a bunch of things together.
Car went from 0.8 to 1.0 Bar withthe tune and exhaust at same time.
I don't think that any other flash tune would have been any better or worse.
