EPL/Tial Alpha 28rs turbos installed
Old 07-27-2009, 08:46 AM
KPG's Avatar
KPG
KPG is offline
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by TiALSport
nope,
A28 is a 48lb/min wheel the 3071 wheel is a ~46/47 lb/min
but you get much more low/mid end with the A28's
the 3071 will be 'reformulated' soon though the 3076's have already been...which is what you want
BTW, what is the lb/min for the wheel in my turbos? Thx
  #167
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
I am still waiting to see some performance measurements such as traps and 60-130 pulls from A28's. Anyone tried these yet?
  #168
Old 07-27-2009, 08:49 AM
TiALSport's Avatar
TiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond repute
Originally Posted by kpg
btw, what is the lb/min for the wheel in my turbos? Thx
58
  #169
Old 07-27-2009, 08:52 AM
KPG's Avatar
KPG
KPG is offline
58
Thanks, I guess I didnt realize they are 20+% larger than a 3071...good for me!
  #170
Old 07-27-2009, 08:53 AM
MBailey's Avatar
all of the above is true (although they have always been called the alpha series), but now we have the finalized version of the A28's which is the only one available now, no other options.
How long have you been selling the "finalized" version?
  #171
Old 07-27-2009, 10:28 AM
TiALSport's Avatar
Late Feb/early March this year
  #172
Old 07-27-2009, 11:30 AM
WOODTSTER's Avatar
58
Holy Crap Batman, that is some Airblow !!
I believe K24/18g's are 40 lbs/min (each, obviously)
  #173
Old 07-27-2009, 11:52 AM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
Art, The only A28 performance info i have is Vince did some qtr mile and 60-130 on his tiptronic car. His Trap was 130mph and best 60-130 so far is high 7 sec range.
His car made 535 awhp mustang dyno at 1.4 bar with meth injection. Now a 6 speed car is making significantly more power and tq.
  #174
Old 07-27-2009, 12:17 PM
art4iza's Avatar
With non ball bearing GT28's, old version we made almost 700wtq @1.4 bar on C16, best 60-130 of 6.14s. You guys need to push those turbos up higher with those light SS housings and new technology. 130mph trap and 7s 60-130 does not make sense to me. True I dropped the weight of the car to 3150 lbs but you guys can do a lot better I think. Any of you guys running C16???
  #175
Old 07-27-2009, 12:22 PM
ttboost's Avatar
Art, if you had a 250lb passenger in your car, could you have accomplished your times? That's the weight difference between your car and most of ours. My 18G/meth car traps 130 and ran 6.2 once, 6.3 a couple of times.
  #176
Old 07-27-2009, 12:37 PM
art4iza's Avatar
Your car is a stand out. I was asking for the A28 style to see a comparison. Realize this, I actually liked when the car was heavier b/c better traction. Having a heavier guy in the car would actually work for the benefit. I intend to have a passanger when I run the TT Gallardo next
  #177
Old 07-27-2009, 12:41 PM
ttboost's Avatar
Heavy is not better! Leave the fat guy home and use drag radials!!!
  #178
Old 07-27-2009, 12:51 PM
KPG's Avatar
KPG
KPG is offline
250 lbs is a HUGE penalty....Actually Art, in the spirit of keeping you slow, if 250 lbs is good, then 500 is better!!!
  #179
Old 07-27-2009, 12:54 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
My 6.2 pass was made with a 180lb passenger, full weight, with 3/4 of gas. I got this weight reduction sh*t down like a pro! But I could care less about 60-130 I think my track times speak for themselves. 109 in the 1/8th mile and 137mph in the 1/4 (was about 100RPM off the revlimiter) talks the talk.
I maybe retiring my oldschool 3076/K24s for a new set of turbos With the new ones, RWD, and Bogarts with 295/45/17" tires I should improve my 1/4 mile time by a LOT! 60-130 should be better on 19s due to the better tire (~25.8") for gearing, but we'll see how the 27" tire does in 60-130.
  #180
Old 07-27-2009, 12:55 PM
vbmw335's Avatar
I will be very surprised if someone can trap higher than 132 with the new A28 turbos. I have done endless number of runs with Vince’s tiptronic car equipped with this setup, its dead even high end, mid range as low as 40 mph start…you name it. Yes he will destroy me if I started from dead stop…I cannot shift from 1 to 2nd gear as fast as a Tiptronic.
Yes with a 6 speed car you will have lesser driveline loss will be faster. Can’t wait to see some real 6 speed numbers.
Quick Reply: EPL/Tial Alpha 28rs turbos installed
