Sidemarker Wiring Connector?
Hi all, My clear Driver side Sidemarker light popped out this week, and unfortunately the wires ripped out of the connector. Does anyone know where I can get a replacement? Please see the attached picture of the connetor. Ideally, it would be good to get one with wires attached, so I can easily splice.
I'd look for a dismantler (a.k.a. junkyard) and ask them to salvage the part for you, and leave enough wire for a splice. I'll bet that's not an overly prized wiring harness, so most scrapped cars should have them.
Paul, oops...I read the wrong invoice...I can't find my receipt, but if you call them and explain what you need, they have it...the socket comes wired and you just splice them into the existing wires. Mine got ripped out when the sidemarker came loose and got caught between the tire and the wheel well.
Ah, that makes sense. I've been in contact with Phil Anderson at Suncoast, however he can't seem to locate the part. Any chance you can find the part number for the connector / socket ?
The part number for the bulb holder is 996 631 133 00 ....perhaps that will help?
I finally got some information from Sunset, apparently it's Bosch BOSCH 1928402078, but I have to order the whole darn wiring harness for just under $400.....
10-06-2015 06:13 PM
10-02-2015 02:23 PM
