K24/18g vs Tial GT28 "alpha," what i'v learned.
#136
When was the last time there was an true "apples to apples" comparison....people race different cars, different turbos, different tunes, different overall mods. I don't see how pump + 50/50 WI disqualifies or makes a comparison unfair. Someone who spends $$$ on ICs, larger intake tracks, weight reductions, etc...and someone else spends $ on a WI kit... go ahead and compare each cars acceleration speeds... whats the big deal?!
That's the big deal.
#137
My point is that you can always find a reason for a comparison to be "unfair" or "inaccurate"...
Oh well....apparently its irrelevant!
#138
Before I read it, I expected the race gas runs to be higher. But I was wrong.
Basically, this article is proof positive how awesome pump+meth really is. You don't need race gas at all.
Some guys take it even further. The HPF M3 guys run their M3's on race fuel+ water/meth. Talk about an advantage!
#139
the big deal is that you cannot say with certainty that your turbos are better or spool faster if you have different conditions. If it isn't apples to apples, then it is just one car is faster than another for multiple conditions. And you are correct, it is never apples to apples. However, if everyone ran a pump file, then you would see who's kits work best under those conditions.
#140
There was no water/meth option for our cars back them. EPL was the first.
But to most people (everyone other than you, it seems), the type of fuel you are running is a pretty big deal. That's why there is such a thing as "pump gas only" 1/4 mile drag days, and "pump gas only" 1/4 mile world records (a Viper holds that one), etc..
We aren't talking about menial things like ICs or intakes. We are talking about the amount of boost and timing you can run on a performance engine. This makes a HUGE difference.
#141
That's the point. People mistakenly assume that you can run more boost/timing with race gas than with pump+meth, but this article shows you can run them at the same levels and make the same power.
But the test was only done at one boost level....so who knows if the race gas set up would make more power at say 15psi (as apposed to the 11psi test) then pump+meth mix.
My car made more power on race + water/meth then it did on pump + water/meth ....wait, does this mean I can still be in the race gas comparison category for those runs?!
#142
So if a WI car runs 1.2bar on pump and a non-WI car runs 1.2bar on pump its unfair? Sorry....I'm beating a dead horse!
#143
Chris,
I thought about it before I posted, And I repeat: I am certain that Scotts old car would have beaten your brothers car in a roll on (as reflected by the 60-130 #s).
OK, let me think about it some more....hmmm...yep....hmmm....yep: Same conclusion, Scotts old car would win. I will think about it all day and my view won't change (although doing so might allow me to steal your official 6 speed bench racing trophy.
#144
I agree with the proof of benefits of WI.
or it water/meth could make more. But for now that is all supposition. If you presume a regular curve, then they might both make equal power. In fact I'd bet that with WI you might be better at higher boost pressures due to the higher heat involved
#145
Sorry.
#146
Yes, they have it for the 'Vette. But I'm not running enough boost or timing to need it at this point. If I go with a bigger blower down the road, then I will definitely get water/meth.
Also, water/meth cools the intake charge...so even if timing and boost are the same, the water/meth car will still make more power since intake charge is cooler. It's like running one car in 70 degree weather, compared to another running in 90 degree weather.
#147
You don't get it. There is no "category". I don't even list the fuel type on the 60-130 list. You ran what you run. Period. But when you try and directly compare a car running water/meth or race gas to a car running pump gas only, you just aren't going to be taken seriously by anyone that knows that they are talking about. Sorry.
And I was joking with the "category" comment b/c you mentioned it in a previous post:
#148
If the timing is different between the two cars, than no, the two can not be accurately compared.
And some cars have larger ICs that lower IATs....people compare those...
#149
just face it your running a race file so what. nothing wrong with that at all. I'd rather run a WI race file than a C16 race file. WI burns cleaner better for the environment, keeps things cooler. To many benefits over C16.
#150
Here's an idea, why don't you completely remove the water/meth setup from your car, and then retune it for 93 pump only...and then redyno. After you see your new dyno numbers, let me know if you think it's the same as comparing ICs....
