997 GT2 Air Box
997 GT2 Air Box
Can it be used on a 996 Turbo ? What modifications would have to be done in order to make it work ? Has anyone done this mod ?
TIA
Enrique
TIA
Enrique
Very nice. My only issue with it, is that I have to cut the plastic thing for my trunk lid. Does anyone know where I can get a spare one ?
Btw, how do you like the intake ? any noticible difference at higher speeds ?
Also, do I have to get my ECU retuned so It won't run lean or will the ECU be able to compensate ?
TIA
Enrique
TIA
Enrique
I'm thinking along ARI's lines....why are you chasing a different airbox if your're not even running at 600? The stock air boxes have been shown to perform perfectly well using the paper filtration system designed by Porsche. I think that some of this hype comes from the claims of higher HP and the spiffy looks of CF....but you drive around with the trunk lid closed....so it's basically for your own satisfaction just knowing there's a CF box back there. Seems to me the money would be better put towards an enhanced suspension system or an upgrade exhaust.
Dixie: What does "works perfect" mean? Sometimes I don't grasp what criteria is used to make a determination of performance levels. Do you have any performance data that shows that configuration works any better than a stock airbox at a threshold at or less than 600 hP? Please dont' take this as me trying to be argumentative....I'm sincerely just trying to understand what difference there might be between an expensive two-holed CF airbox and what I'm currently running that came with the car.
What I mean with car runs perfect is : no problems with MAF or anything else,
Does the box give more power,I don't know but it certainly isn't slower,Porsche made for the 997TT also 2 holes,so I suppose it isn't a bad thing to do and it looks good..You don't need a retune for this air intake..
The Agency Power Carbon Fiber Dual Flow intake is basically the stock airbox but designed to simulate the 997TT airbox with "dual inlets". The intake was designed and made for those above that like the stock airbox. The added benefit is improved airflow to the entire surface area of the filter. Also the intake makes the turbo spool up more audible and looks great! No retuning is necessary.
Thanks guys and Dan.
Well I have a flash, exhaust. I don't want to change the Turbos out yet. So i'm trying to get a bit of power by doing some other simple bolt ons. If i can't do bolt ons then i'll do more weight reduction. Any tips in simple bolt on mods to get more power ? I'm thinking the GMG CF roof if I can't do any simple bolt ons. I just have to make sure I can keep my roof racks.
TIA
Enrique
TIA
Enrique
Enrique: You're looking for more bolt on power, so you're thinking about a CF roof? I think MA Shaw sells one that adds about 25 HP. ![Big Grin](https://www.6speedonline.com/forums/images/smilies/biggrin.gif)
Seriously...you're looking at spending some serious money for bling. If your objective is how cool the car looks, I can understand, but to say you want power, but are looking at expensive CF is contradictory. If you have the K24 turbos...go for the wastegate kit....great bang for the buck. About $395 from UMW....but you should check with your tuner to see if you need to retune for the wastegate kit. Probably not.
Chuck,
No, I track my car pretty often, I have a lot of weight reduction mods. I want a bit more power but IF I can't get it I will take off weight instead of adding power. I'm not doing it because it looks nice
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
To give you an example, with my new seats/weight reduction mods/suspension/alingment I was running 2 min flat at Thunderhill dipping into 1:59's
Dan,
That is a very nice offer. I'll let you know let me just get some more feedback as what people think what route I should take.
You do a lot better at Thunderhill than I do....I see your approach now that you've explained it better. Since you're running K16's, you can't do the wastegates. If you're looking for weight reduction, from a weight saving perspective, the airbox won't do much of anything for you except look nice and give you a bit more sound feedback. Not knocking the product, just following your logic trail.
Maybe we'll meet up at T-hill someday.
