Inexpensive 996 TT Headers. Too Good To Be True?
As external WG vent to atmospheren they have a potential of being quite noisy when they kick in. I personally think any noise over a nice throaty sound of a carefully selected after market system, while OK on the track, is somewhat undignified on the street for this caliber of car. When I had my straight pipes they were far too noisy for my liking. So I went to a system that I selected for a compromise of sound vs HP.
I am sure if you like it, then that would be fine.
"As external WG vent to atmospheren they have a potential of being quite noisy when they kick in "
ah cmon that is the best part !!! nothing sounds better then hearing my turbos spool up and the WG open at WOT .... simply intoxicating. lets peopel know that car means business...
also, u can re route them back into the exhaust and they will be very quiet that way you wont ever have to deal with rods braking , or the actuator springs beeing stuck open ... and they are much much more accurate then the stock actuators.
very true. Even an NA 911 with straight pipes is 3-4 times louder than a turbo with straight pipes. With cats and straight pipes it is not to bad, just drone hurts inside. but everyone has a different tolerance to noise.
Cheap means not good..True..
but as I know some indenpendent tuners got their header made in CHINA as well but from professional and high standard manufacture.They made what tuner designed and accepted with tuner only sold the parts to tuner for resale.
You would call that crap header but not chinese crap.Not everything made in CHINA are craps.It depends on how much you paying and what market your business targeting.Many people need cheap things.They need cheap things for their poor life..Chinese know how to make cheap things and have cheap labour to do that.Thats business issue nothing nationallty...
In doing business with China it is possible to buy very cheaply-- often it does not cost a lot more to buy very adequete quality. In ordering, the buyer( I am talking quantities) needs to have a clear idea on what is required or you can finish up with rubbish.
For those that cannot remember--everything that came out of Japan was once considered rubbish,including their cars,look at them now-you could hardly be critical of finish and design integrity.Need I point out-- how well made are a lot of American cars.
In time China will move on from the price only issue- in the meantime look at it realistically and with not too many pre conceived notions.
I'm quite sure that no one here meant any offense to anyone. I think those of us that responded to this thread, responded with experience to buying "inexpensive" headers. Stainless cracks anyway, thin stainless cracks even easier. It's these thin stainless headers that are giving the inexpensive headers a bad name. It's just by chance they are made in China. We make junk here too...
welding stainless is part of the problem. the other part is knowing that you got the right stainless and without a metal analyzer of some kind, there is no guaranty of anything if it comes from Asia. The third part is how that metal was processed. because of it's chromium, stainless has good heat resistant properties. However, because of chromium it can be more brittle and crack. There is more control of what you are getting in European and American products IMO. Good luck.
On a turbo car of this quality, is it really necessary to upgrade the manifolds? Porsche put alot of research into making a manifold that provides enough gas flow to spool the turbos proper as to not cause excessive lag. If this was a NA car, I would be more likely to agree with upgraded headers. The question I have is are the stock headers a limiting factor? I believe that you can upgrade the turbos, bore, stroke and etc. enough that the manifolds would be a limiting factor. But is it needed for the k16 and k24 hybrids that are popular?
Yep I agree Larry... The sad thing is so many places these days sell them. If they're cheap... then we know why. I've nothing against cheap but stuff like this is going to crack etc....
At least spend the money saved on doing a before and after. Too often people believe all the hype sadly;(
