K24/18 996tt against C5Z06 w/cam and 100shot
#33
Chris, don't forget that P cars have a lot more TQ and that's where the power is. You gotta have a good driver to bring out the best of the car. HP only comes handy when running high gears above 4th. I like the dyno sheet on the first one but bring that on dyno dynamics and you will see a very disapointing number. HP to weight also plays a role like you mentioned.......it would be big shocker if I ran that Vette with my old set up....just a hint....weighs less than a Z06
#34
#35
Thanks for the kind words. It's actually not too impressive, I know of one that weighs at 2600lbs with well over 1000HP, now that is scary No clue on the shots.
Your car weighs under 3100lbs? If so dam thats impressive. The thing with a nitrous car is theres no lag just straight horsepower. Depnding on the cam it has it could easily be 550whp with spray. These cam only cars as chevy guys call them are misleading. It might have stock heads but they still might be worked over. If its geared I hope you have your race gas because your going to need it. With the rigt tire it could easily be a 130+mph car. I hope he doesnt rejet the car for more hp because if he does you might have a loss. Do you know if its a wet shot or dry shot?
#36
People seem to underestimate nitrous cars and N/A Vettes or cars in general. Comparing a supercharged car to a cam/n2o car is like comparing apples to oranges. Something to remember Supercharged cars make their power as they get higher in the RPMs. An N/A or n2o car makes its power down low and carries it through the RPMs. Much like a turbo car, well sort of... The turbo car has to come into boost first (with load), but when it does it makes the power and carries it. The supercharged car is going to get dominated all through the curve until the top of the graph when the blower is really spinning and huffing out air. Which is why a car with less power thats turbocharged, n2o, and N/A car will keep up with higher HP blower cars. They just get dominated under the curve.
The Vette also has a weight advantage over the TT. In the C5's case it's anywhere from 150-300lbs depending on the type of Vette it is. People keep throwing the numbers down and are like well you make more therefor you will win. That's all in theory. My brothers C5 FRC (Hardtop, the Z06 style body style) only made 527rwhp on one of Houston's most leanity dynos, and 506rwhp on the dyno where I dyno my Porsche at. It managed to run a 10.55 @ 128mph (letting out) followed up by a 10.6 @ 132. When we lined up with me on 19psi (with no brake boosting) he jumped out over 3-4 cars on me before I even got into boost. I would have had to shift into 5th if I wanted to pass him (I was already at his rear bumper). His car makes 50 more RWHP alone N/A and it's hard to know how much on N2O because of wheelspin on the dyno. The car is a force to be reckoned with on motor unless you are Sean, Rob, or I. There are even faster N/A Vettes in America than his, so just remember that when you line up to anything that has an N2O setup or a lot of HP N/A.
I'll add a picture so people can see what I'm trying to say:
Supercharged Vette (not sure the owner or mods, but it's not going to drastically change the curve).
Nitrous Vette (My brothers car, on it's old cyl. heads, only thing that will change on the curve (if it could dyno clean on the n2o) is that it will shift higher because of more HP on motor and the ability to flow the n2o better). The reason for the step in the curve was the progressive not being set. When we didn't use it on the recent pulls it just ended up in wheel spin.
Regardless of who wins... Just make sure you are safe Do the runs on an abandoned old Mexico highway.
I complete agree with your thought process. Small blocks can be a beast on the pavement and can demoralize an unsuspecting victim. They have basically instant torgue, many of them run laughing gas and are geared for the streets. Your brothers vette, Scott's vette and the killer of them all boosted out of Dallas would make believers out of dreamers.
Cheers
Robert
#37
#38
I'm just going to say though it could be a lot closer race and not a immediate win. Hell you may destroy him, or vice versa. Street racing always has factors LOL!
#42
Unfortunately local shop didn't have any unleaded race gas so I'll be ordering some, although I don't have a race tune yet. I'm currently running 1.2bar with spikes to 1.3 bar on a pump gas tune from EPL. It's all in good fun and I have had a real race since I got this car. I pulled pretty good on my friends Evo on the way back from Titan and he traps 123-125 pretty consistently.
