houston, raising a car on coilovers?
Old 07-24-2009 | 11:01 AM
ixotuckeroxi's Avatar
ixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to behold
hey guys,
taking the car to alignment shop but my car is too low to get up on the rack. got a couple of questions...
1. how do you raise a car on coilovers LOL
2. if you were to raise the car 1 inch on the perch of the spring, does that equal 1 inch increase in height?
3. where to purchase/borrow/rent a spanner wrench for bilstein coilovers?
tia fellow gents!
Old 07-24-2009 | 12:16 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
If I went to a shop to get an alignment and they could not get my car up on the rack cause it was to low, I would not get my alignment done there.
Old 07-24-2009 | 12:25 PM
WOODTSTER's Avatar
drive up onto 2x6's (1.5" tall),
that should do it.
Old 07-24-2009 | 12:26 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
What he said.
Old 07-24-2009 | 02:03 PM
sweeney186's Avatar
sweeney186 is infamous around these parts
1- woodblocks-2x4's etc work great-use them quite often in changing from street to track settings
2-depends on where the collar is on the shock & spring rate-but genrerally no
3-http://cgi.ebay.com/ebaymotors/Motorcycle-Tool-Shock-Preload-Adjuster-Wrench_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a 2Q7c39Q3a1Q7c72Q3a2127Q7c293Q3a1Q7c294Q3a50QQ_trks idZp3286Q2ec0Q2em14QQhashZitem33543bea23QQitemZ220 456544803QQptZMotorcyclesQ5fPartsQ5fAccessories
is what I use
Old 07-24-2009 | 02:16 PM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
Your car should be aligned at ride height. If you raise and align, it won't be right.
Old 07-24-2009 | 02:26 PM
911TurboS2's Avatar
911TurboS2 has a spectacular aura about911TurboS2 has a spectacular aura about911TurboS2 has a spectacular aura about
what he said
Old 07-24-2009 | 02:31 PM
Dr_jitsu's Avatar
plus 4....where are you going, Joe's Chop Shop?
Old 07-24-2009 | 03:32 PM
no, but the car has the pp techart front bumper and the lip installed. it doesn't really make it over the hump to my driveway much less up on any automotive rack.
appreciate the helpful replies, im just going to have the front bumper removed for alignment.
Old 07-24-2009 | 07:07 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
What a PITA Tuckster. You're a baller bro. Too low for an alignment. You've been hanging around Edwin too long.
Old 07-25-2009 | 07:38 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Isn't the lip on with 4 fasteners? Just remove the lip.
Old 07-25-2009 | 08:16 AM
haha, its probably in my best interest to raise the front at least .5-1" if i wanna keep the front splitter/spoiler.
lose an inch on the car, i just lost 3 inches on my truck, went with 44s instead of 47s for driveability. doesnt help being half asian, whats next? LOL
function, i have no idea. ill have to ask the bodyshop. i havent seen the assembly of the front end.
Old 07-25-2009 | 05:05 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Tucker call Steve who was at the 60-130 and see who he suggests. 281.841.2798.
Old 07-25-2009 | 09:29 PM
ben,
appreciate the tip! will do bro, thanks!
Old 07-25-2009 | 09:48 PM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Originally Posted by ixotuckeroxi
hey guys,
tia fellow gents!
Tucker,
a 1" on the perch of the spring does not equal a 1" increase in ride height based on my experience. The best way I've found on how to do is spend time working on one corner (adjust perch, put wheels on, drop car on ground and repeat). Once you found that perfect height, count the threads on that coil and do that on the other side.
It slips in between the "fangs" of the bumper and then should be bolted on.
+1 - Steve will know who to go to.
Edwin
Quick Reply: houston, raising a car on coilovers?
