Z06 vs GT2 (Original, I know:)
Old 07-31-2009, 03:20 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Art the caddy,but I might put a 100 shot just so I could beat Seans M3.
  #47
Old 07-31-2009, 03:21 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Originally Posted by vbmw335
That Gt2 cannot be stock. That's almost 70 more whp than a stock #, must be flashed. The Z06 #'s seem right.
This was the stock dyno on my Gt2. I wanted to use it as a reference to see what I gained after my flash, exhaust and waste gates. I'm not saying that it is accurate, but that's what the numbers were.
File Type: pdf
  #48
Old 07-31-2009, 03:23 PM
Chris that is very impressive to pull the wheels with front wheel drive, wouldn't you say?
  #49
Old 07-31-2009, 03:40 PM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
now thiking about it ..maybe possible. most stock 996 tt dyno about 330-350 on mustang awd dyno. So on a dynojet its about 15% more..and then the gt2 has k24 turbos ...so about 430 is possible.
I guess i was wrong to doubt the hp on dynojet. They always read higher than mustang and others i am used to.
  #50
Old 07-31-2009, 04:39 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Impressive numbers.
  #51
Old 07-31-2009, 11:09 PM
AtomicZ's Avatar
AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !
Originally Posted by DJ'sZ
I'm in anytime...too bad I'm in Texas...not sure if a 40mph roll would be great for the Z06.
At 40mph where are the GT2's in the rpm range and what gear...? The GT2 may pull the Z06 slightly at that speed I'm not sure. 60-70mph roll the Z06 will probably pull slightly.
When it goes into the dreaded 5th in a 'stock' Z06 the GT2 will start pulling away or gaining slowly until the Z06 gets back into its power then the GT2 would stop pulling. Just not sure if a stock Z can reel a GT2 back in if it's ahead at that speed...I'd love to try it though.
I would agree that 70 would be a better mph for Z06. My car from 40 is pretty dead even with Woodtsters 996TT but from 70 I can pull a little on him. 5th gear is a bummer in stock Z06's. That is why I have changed out 5th & 6th - now it pulls strong all the way through.
Very close to what most stock Z06's dyno. Would be a very good race.
The_Ruski_Driver
10-25-2015 08:40 PM
RallyBird
10-07-2015 01:20 PM
turbotuner20v
09-11-2015 12:02 PM
Murf4
New Member Introductions
09-03-2015 10:10 AM
Quick Reply: Z06 vs GT2 (Original, I know:)
