IPD 75mm plenum installed on my k24/20g by IPD Mike!!
hi, ya my torque was 608, the last pull was at 1.4 bar on c16, i'm definatly gonna get some time trap speeds for you guys. cheers thanks
Big ups to Sid for posting. Good times at the BBi dyno day guys. Thanks again Art.
630rwhp translates to a much higher number on any other dyno.....take it from brother. You are pushing 730-750 crank HP If at any point you guys need clutches let me know I have two bad a$$ ones that you guys could use. One is Sachs and one is Tilton (the tilton one holds 700rwqTQ and does not need to be adjusted every 3000 miles unlike the triple disc).
Well i wanted to share my experience and i finally did it and wish i had done it sooner! The plenum was installed with a matching 75mm tb. i actually called Turbo Mike for a hand, he machined and welded a new end piece to my protomotive intake y pipe to match the new tb. Thru the intsall, Mike made sure everything went smooth, no leaks, and perfect fitment!
My 1st impressions, the car revs much quicker! Now while driving the car the throttle is very responsive and At wot you can feel the mid range power pulling much, much better!!! Overall i'm very happy with the added benifit the plenum adds to the car. I took some pics and will post shortly. I want to thank Mike for the helping hand with the fabrication and the installation. The plenum overall makes the car pull better thru out the power band!
proto intake w/ blow thru maf, proto tune, 60 lbs injectors, 2nd fuel pump,greddy ebc, evoms ic, ipd plenum/tb, clutchmaster stage 3, 3" exhaust(no cats), kw v3, kinesis k19r, the car runs very strong.
Any before numbers on the same dyno?
Any plans for 60-130 ? 1/4?
Sorry no before #s, but when i do get some times i will post asap. cheers
