P0455 - Porsche Fault Code 94 - Tank Vent System (Major Leak)
One simple thing to check is the gas cap. But the problem is more likely with the fuel filter and/or its connectors as it is mounted to the coolant reservoir. BTW, if there was no CEL, how did you realize there was a code thrown?
Thanks, I did clear the fault and tighten gas cap. It has not come back...
Thanks for your response.
joseph_number1
07-19-2018 05:45 PM
