Project Ghetto Boost Gauge... NO MORE
Stephen sent out one of his trick units that has been modified to fit into the batwing (very cool btw) and after locating a wiring harness (to hook up to the unused phone connector) from a local boxster owner, my wife got out her crimpers, wire cutters, hair dryer etc.. and went to work on it. The end result is a high quality boost gauge (in PSI woo woo), which upon reflection I have to say reads different to stock. Not only is the stock one laggy but it's off by a couple of PSI here and there. Either way, thanks Stephen.
I'll post some pictures of the finished install (I know Stephen posted some too a while back). Once I pop out the rear panels and run my vacum/boost hoose inside the car as opposed to outside with duct-tape![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
Once again, I'm not sure if Stephen is going to make many of these but they're very trick.
PS Only thing I didn't do was wire it to the "DIM" (not sure where to tap in anyways) so it stays bright at night as well. To be honest, I prefer it not dim anyways...
Pharris409
11-01-2015 06:57 AM
johnny.dangerous
09-11-2015 02:39 PM
