Airbag fault warning
I just had this happen. It said air bag failure. I took it to the dealership (CPO) and the code said that I had a power interruption. They reset it and looked at the seat belt connections but they could not find anything and it has not happen since.
It can be many things if you look at this list. But probably only a reset will erase the message as per "bdb". In any cases you have to get the code retrieve and evaluated.
also, your info on the spacers was helpful too.
WheelsupZR1
10-20-2015 08:36 PM
