Misfires Fixed - Avoid Denso Iridium (IK20) Spark Plugs (pic)
#52
Back atcha my Gel batteried friend.
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
#54
996 turbo
Vinny
#55
Im pretty new to this..Im in Palm Beach FL too...I have 2004 /996turbo.I just flash ECU at FVD and by pass Cat.Last week i was driving with higher boost at 55k RPM and Check engine Light flashed then came up...the code said misfired cyl.3,I didnt fix the problem yet but the code was cleared by me.Please help any sugestion with the spark plug will compatible with my higher boost-u know any 1 around us to do the job?what kind of plug i should buy..please help....aftaer i clear the code..no light come up and car idle normal..but i felt i didnt have that much power like before.Thnksssss for help.
Vinny
Vinny
#56
Vinny
Vinny
#59
Vinny
Vinny
Mike
#60
I went thru the same thing in May. When the engine was under full load with boost 1.1 to 1.2 bar, the car was misfiring really bad. This happened at the top of 3rd and 4th, 5th & 6th. My car had stock plugs installed . All of the research I did pointed to the plugs being gapped too large. The increased boost pressure actually blows out the spark causing a misfire. The stock plugs are gapped at 0.06"±0.008" from the factory. Under direction from friends and tuner, I changed my plugs to a Denso 3245 (PK20PR-P8) Gapped at 0.028". I also changed all the coil packs to 997's at the same time. The car has run perfect since. It makes great power without any hesitation. I would recommend this to everyone!
